One bad ass Art Carr gate shifter
Discussion in 'The Garage' started by yunit, Oct 20, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Don't sweat it to hard...AIGHT!
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Oooowww, rear cable exit and a skull. /forums/images/graemlins/thumb.gif How much? Did ya get a deal on it? /forums/images/graemlins/thinking.gif
  3. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    i like the sheetmetal mount. you gonna leave it like that or are you gonna strengthen that up some?
  4. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    If you call $285 a deal. /forums/images/graemlins/tongue.gif
  5. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    That is a piece of 1/8" stainless steel. Have you ever tried to bend stainless steel before Matt, it is pretty rigid stuff, no need for any more support...plus it is only temporary until the cage goes in. /forums/images/graemlins/thumb.gif
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Alright...I'll play the ignorant one; what's cool about those? I guess I don't get the whole floor shifter thing. What's better about them?
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Limited knowledge, but I beleive the gate helps prevent an accidently shift into another gear.
    Plus with this shifter, kind of odd seeing it mounted like this, but it is used real heavily in desert racers and you will find it stationed on the right side of the driver, either right beside them or a little bit forward and it's a lot easier shifting with the shifter in that position. The shifter is on a console that is about chest high, I've even seen them almost neck high, right in about the same area as the radio. A lot better than a column shift.
  8. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Also in a really flexy situation, the stock column shifting setup can bind up, while a cable system doesn't. IIRC, yuint is probably running a tranny with a reverse manual valve body, meaning that he basically has a manual auto-matic tranny...if that makes any sense... /forums/images/graemlins/tongue.gif
  9. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I've got your back dude..............
    A manual valve body means the tranny now has to be shifted manually. The reverse manual valve body means that the shift pattern is now P-R-1-2-3..............
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] only way to go auto I think, if that makes sense. if I ever build a buggy it will have probably a th350 with manual valve body.
  11. heavy4x4
    Aug 28, 2002
    3,270
  12. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    Thanks Bubba /forums/images/graemlins/thumb.gif
    BTW, when's the Aggie and OU game, or should I say O who? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sweet! Looks almost identical to the mount I built for my B&M. I love my raised-n-kicked mount, but I HATE that B&M. I think it will be replaced by an Art-Car when I recover from my current budget over runs.
  14. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    sweet shifter. Id love to have one like that, cable operated and all. Be handy to mount nice and high, since I cant reach chit on the floor with the 5-point harness on. /forums/images/graemlins/grin.gif
    j
  15. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    The best shifter I've ever had...
    you can pour sand and dirt and beer and soda all over it and it will shift with ease. I love mine. I don't know about you all but getting rid of my stock column shifter and steering column got rid of a lot of binding and moving parts that fail ( I once was stuck with a broken rack gear in my steering column without tools to remove it and fix it.
  16. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    ...I don't know about you all but getting rid of my stock column shifter and steering column got rid of a lot of binding and moving parts that fail ( I once was stuck with a broken rack gear in my steering column without tools to remove it and fix it...
    That's what I was trying to say. On a trip once one of my friends lost the kotter pin in the linkage on his tranny and he couldn't stay out of Drive, so we found a paper clip in a gas station parking lot and rigged it in there and got to the nearest parts store.
  17. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Add a manual lockup torque converter to that with some sort of lock/unlock switch for it on the shift knob and you'd have the only flavor auto tranny I'd ever run.
  18. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    so what happens at the linkage to the tranny? im having a hard time imagining how a cable can move the lever around. i can see how it could pull it, but how does it push it back? pic maybe? thanks
    very sexy BTW
  19. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    very sexy BTW
    It's a push/pull cable, similar to the cables on our emergency brakes(but bigger). The cable inside the conduit isn't flimsy like thinner cable so it's able to push the linkage back.
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ahh you guys need to do like my dad on his circle track street stock. Cut a flap in the floor, take a LONG rod with threading on the end and run it through the flap right to the linkage. Then add an SM465 shifter knob(K5 donated) to the end and go for a drive. Not fun to shift but it gets the job done.
