One last trouble shooting try.....and that's it
Discussion in 'The Garage' started by 78Suburban, Mar 18, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I know most of you are sick of these posts. There are no nearby ck5ers. If I can get the burb to at least run long enough to idle, I'm going to pull the valve covers and see if I see any loose or funky rocker arms. It might be a simple fix somewhere in the valve train. What valve cover gaskets are good to use with stock steel covers? Should I use any RVT on them too? How tight do I put the covers back in order to not pinch the gaskets?
    If I can't figure it out by pulling the valve covers and having a look, I'm going to use my $300 birthday money to call up a tow truck, have her hauled to a mechanic, and cross my fingers that he doesn't try to stick it to me for as much as a gm crate motor would cost :eek1:
    Unless somebody that lives near middle Georgia sees this and wants to come try to help, then I'm going to pull the covers and if I can't tell anything, off to the mechanic she goes.. Now if only I can find a reputable mechanic that will not charge me an exortionate price.
    thanks,
    James
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I only use a light/thin coat of RTV on the valve cover side, just to basically hold the gasket in place, the head has a slightly rough surface, so it will basically grip that side of the gasket.
    Everytime i used to RTV both sides, they would leak, or squish out of their seating position.
    I usually use the felpro brand gaskets.
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Bingo thats what i used (Cork) and i didnt use any sealant just tighten the screw down hand tight then use a ratchet to snug them.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    So what is the problem you're having? Also a cork gasket is much better than the rubber and i only use a few drops of silicone to hold the gasket in place on the valve cover while i install it.
