One mo thing...Whut is a "gov lock"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rastaska, Apr 17, 2000.
  1. rastaska
    rastaska Registered Member
    Apr 17, 2000
    5
    So. Cali
    One mo thing...Whut is a \"gov lock\"
    Hello, one more time...anyone knoe whut a "Gov Lock" is...a guy at Four Wheel Parts said that it is wearing down and should be replaced???
    THanks
    Steve
  2. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Re: One mo thing...Whut is a \"gov lock\"
    A Gov Lock is a factory installed limited slip differential available from GM as an option. Mine hasn't worked in about 3 years. When I swap axles, it won't make the move.
    Kyle
    89K5
  3. CK5
    May 19, 1999
    21,625
    702
    CO
    A gov-lock is a GM factory LSD (limited slip differential) that was used mostly in corp. 10-bolts. It uses a series of plates much like clutch plates that is used to transfer some of the power to the other wheel that needs traction. Gov-locks are mostly considered weak and are a good canidate to replace with a stronger locker.
    Steve
    Someone let me know if I am off-base with this description.
  4. rastaska
    Apr 17, 2000
    5
    So. Cali
    Sorry, I am kinda new to this whole "differential thing"...What is a LSD (Limited Slip Differential)??
    Steve
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    A differential in the part inside of the center of you axel housing ! The center housing is also called a pumkin. The differential is the center of haveing trackion or not having tracktion to both tires. LSD is a diff. that will preload both sides so when you step on the gas both tires will spin while still alowing them to spin at different speeds so when you turn a corner the inside tire won't churp,churp,churp.A locker will make both tires spin at the same speed all the time so now the inside tire on a turn will go churp churp churp.
    This is the way I think about it so I hope it helps!
    Rock ON![​IMG] 72 K5 [​IMG]
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Nicely politically correct way to say that a Gov Lock is JUNK! Nice job Steve, you could run for office! [​IMG] You are right on base, just being too nice about it!!!
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I believe the Gov-Lock was also the factory option limited slip in all the truck rear axles from S-10's to 1 tons........
  8. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    Go rent "My Cousin Vinny"
    movie has a lot to do with
    limited slip diff ...
    last 1/2hr does anyway
