ONE MORE QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TB2Blazer, May 7, 2003.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    Is there an inexpensive way to convert a six lug ten bolt to an eight lug?
  2. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    It is not cheap. You have to replace everything from the knuckle out. Usually a junkyard wants as much for the parts as for the whole axle.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can make the whole swap (front end) for around $300-400. Sometimes less depending on parts cost and how much needs to be replaced.
    It could be easier to just use the 8 lug to 6 lug spacer plate to make an 8 lug rear 6 lug. The spacer is $250 and you don't need new rims.
