One more quick questions...part number...
Discussion in 'The Garage' started by grafixxman, Oct 2, 2005.
  1. grafixxman
    grafixxman Registered Member
    Dec 1, 2004
    70
    Can someone give me a part number and company who makes it for a good set of poly urethane sway bar bushings for a D60 swaybar please? If it matters, it is a complete front end out of a cucv 1008. and it will be under a K1500.
    Thanks,
    Tyler
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Well, I use some Energy Suspension produsts, and I am bery happy with them. You would need to measure the sway bar to get the exact one you need, im sure the newer style will fit the older style if the shaft is the same diameter. Atleast it did on my 1/2 ton.
    http://www.energysuspension.com/pages/c4wd1.html
    Daystar has a complete catalog online and shows the part # to be KG05003.
    http://daystarweb.com/catalog/
    Good luck...
