One more time and a 10 bolt is going back in.
Discussion in 'The Garage' started by CK5, Jun 27, 2003.
  1. CK5
    May 19, 1999
    21,625
    702
    CO
    Just kidding - But I am getting real sick of replacing grease seals in my 14 bolt! Should I try a speedy seal this time? Everytime I replace one it works great for about a year than bammo, leaky as 14-bolt.
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Is this on the pinion or the spindles?
    Are the seal surfaces all scoured up? If so, then yeah try putting a speedy sleeve deal on it if you can't clean em up with emory cloth.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    My pinion seal was actually leaking around the metal part of the seal. I seated it with silicone and problem went away.
    Nobody likes a leaky messy, and unsightly rearend. /forums/images/graemlins/rotfl.gif
    Oh yeah, if it is the wheel seals the you might not be running enough torque on the nuts.
    Can you feel a groove on the places where it leaks?
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Your using quality seals I hope!!! /forums/images/graemlins/smirk.gif
    I use Torco GL-6 85W140 racing gear lube... /forums/images/graemlins/pimp1.gif
    It's more like the sulfer based lube...
    that was used in the sixties and earlier..
    It's a VERY STICKY LUBE...
    It may help preserve those seals...and keep down the heat!!! /forums/images/graemlins/thumb.gif
  5. CK5
    May 19, 1999
    21,625
    702
    CO
    Sorry, it is the passenger side spindle, I haven't taken it apart yet, I didn't see any deep groves or anything last time I changed it.
    I believe I got the seal from Napa last time, is there a better one, maybe a dealer part?
    Anybody use a speedy sleeve? part number?
  6. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I had the same issue with the drivers side seal of the 14 bolt. There was a nice sized groove from years of use that I couldn't avoid. A speedy sleeve from NAPA fixed it right up. No leaks for over two years now. I don't have the part number, but someone else should.
    BIGJ
  7. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I've been running 14Bs since 1986 and have found that the GM seals hold up the best. If your spindle is good and you have a quality seal it should last at least several years. It got to the point that I only changed them when doing the rear brakes. Maybe you need a speedi sleeve?
  8. CK5
    May 19, 1999
    21,625
    702
    CO
    I have to go to the dealer and get a flange gasket anyway, so maybe I will get the seal there and slap a speedy sleeve on wheather it needs one or not.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Drop a PM to stoopalini. I think he put speedi-sleeves on his 14-bolt. Maybe he's got a part number. /forums/images/graemlins/cool.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Car Quest part number #99282 is the speedi-sleeve. Around $50 for a pair. /forums/images/graemlins/tongue.gif
  11. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I kept a copy of this from a long time ago...
    Speedy Sleeve for 14BFF
    Reged: 10/17/00
    Loc: Austin, Texas
    Re: Calling All Speedi-Sleeve Gurus... [re: aandpman] 05/09/02 02:27 PM Edit Reply
    Hey, I did a writeup on a speedi sleeve install, but the host that it was on is no longer up. The NAPA part # is 'OIL SEAL P/N# 99282' I'll email you the write up with pics so you can check it out. Maybe I should send it over to Steve? would be a good article for the tech section ..... Thomas. ------------------- '84 3/4 Ton Blazer Post Extras:
    aandpman
    CK5 Member
    Reged: 09/06/01
    Loc: Crockett, Texas
    Re: Calling All Speedi-Sleeve Gurus... [re: Stoopalini] 05/09/02 02:39 PM Edit Reply
    Thanks for the info..... That would be a great write-up for steve to put up in the tech section..... Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. 85 K10 14bff & D44 in works;) Post Extras:
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Beat ya to it! /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
