one more time around
Discussion in 'General Parts for Sale' started by jjlaughner, Nov 7, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    8?-91 blazer/pickup/sub aftermarket fenders Left and Right (horizontal turn signal), in good shape with inner wheel wells -$65 for all four pieces
    8?-91 Blazer/pickup/sub inner wheel wells have 2 lefts and 2 rights in good shape - $25 a set
    79 carbed shortbed fuel lines and brake lines - $15
    14bff from a late 70's early 80's 3/4ton pickup (should be 3.73's might have a gov loc), sticky brakes and ebrake lines are cut - $60
    10bolt non-flatop knuckles - $25 for the set
    poly upper frame bushings (upper front shackle) with sleeves for 7/16" bolts - $15
    8lug backing plate/bracket for D44/10B, just the caliper bracket not the full disk cover type - $20
    10bolt 6lug rotors and hubs (small type) - $35 for the set
    milemarker locking hubs, look nice, have in box ready to go - $40
    86 blazer fuel tank and sender - unknown condition, used for 2 years then sat in a barn till last fall, outside looks good no dents or rust, unknown sender condition - $40
    SRW 14bff hubs and drums - $60
    monroe sensa trac shocks for stock height blazer,burb,pickup used for about 6 months, parked 6 months, been off the truck for about 6months, not many miles on these $120 new $45
    Spare 14bff axle shafts from SRW 14b - $20 short and $25 long
    chevy hitch symbol, chromed plastic - $10
    32x11.5x15 goodyear wrangler AT/S's with a tiny bit of tread left on factory rallies, good for around town or to roll a project truck/frame around on - $50
    2- 285r75/16.5 BFG AT's (about 31-32" tall) with a little tread left on 16.5" 8lug rallies, good to replace bald tires or carry as spares - $40
    40 gallon tall reptile tank, custom wood finish (nice), screened in top with slide off cover - $40
    10 gallon reptile tank with slide out screen top - $30
    10 gallon reptile light/heater cover, has florecent bulb and two heat lamps - fixture alone was $125 bulbs another $30, will take $100 for fixture and bulbs, very little use it wouldn't fit on my shelf /forums/images/graemlins/doah.gif
    COMPUTER networking, video cards and cables - email/PM with questions/requests
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Is this for only 1 side or a pair?
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Both sides, they got a little tweeked moving the axle around so they might need some straightening (not bad though)
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    JJ..any pics of the 40 tank setup?
  5. grundy99
    grundy99 1/2 ton status
    Sep 13, 2004
    389
    Loveland, CO
    Do you have any pics of these? Have they been cut or anything?
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    It was a fish tank but someone lifted it from the center strap and broke it so it can longer be filled up, might be good to fill 1/3rd of the way up with water for turtles or salamanders.
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Nope no cutting, the turn signals got broke but there are no dents, they are still in black primer
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Does the python come with it? /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
    yes i know the tank is empty
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    sending a PM /forums/images/graemlins/thinking.gif
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    bump
    buying another gun, need some cash!
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/dunno.gif
  12. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    if only 14 bolts could fly
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    it might the scrap yard here has this huge magnet on a crane.... /forums/images/graemlins/ignore.gif
