One person removal/installation of topper.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Goose, Jun 15, 2000.
  1. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I've seen quite a few posts dealing with how to take the toppers off and on. I keep getting stuck trying to do it by myself and have come up with a way to do it that can work anywhere.
    Removal:
    Take out all bolts and leave tailgate up. Get in the back and lift slightly to break seal and start to slide off the rear. Get out and go to the rear of the topper. Pull the topper rearward until it's well past half way. You will be supporting most of the weight, with only about a foot or two still touching the K5. Slowly let your end down entil it rests on the ground. Try not to let the topper slide, just pivot at the end of the bed. Have a piece of 2x4 or whatever about 5' tall. Crawl underneith the topper, push it slightly away from the K5 and prop up with the 2x4. Pull the K5 away, go back and take out the 2x4. (Actually, I do this in the yard and leave it in nuetral, then I just push the K5 forward while holding up the topper.)
    Installation:
    With the topper propped up with the 2x4 slowly back up until you're as close as possible. Remove 2x4 and rest topper on end of bed. Go to back of topper and lift. Then carefully slide forward and re-install bolts.
    I have a '73K5 that is missing some of the seal hardware where the tailgate and bed rails come together. This makes it a little easier because there is nothing in the way. On the newer one, you will have to be more careful, but it can be done.
    Mud is just thick water, or is it that water is just thin mud?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I think my way is a little easier, i take out the bolts, break the seal, then prop it up on some scrap 4x4's then, as suggested in teh owners manual, i bolt a couple 2x4's to it side to side, one in front and one in back, then i throw down a couple towels to keep from scatching the paint, then you just slide it off the back onto the custom, 4& 1/2 foot tall saw horses i built, i do it all by myself, every year, untill the neigbors call the cops about the "camper shell" in the front yard. I hate my neigbors. they just don't understand car people.
    RaisedK5
    "Friends don't let friends drive Fords"
  3. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    it's when i was sliding the top up towards the cab when the incident happened. as soon as i clean out my garage, i'll rig up a pulley system. until then, i think i'll stick to utilizing my co-workers' backs.
    <font color=purple>delta9blazer</font color=purple>
  4. Glenn
    Glenn Registered Member
    87
    North Kingstown, RI/USA
    I do the same thing with my 87 but I just rest it on the ground and then flip it over backwards on the ground. When I put it on I pick it up and get under it and then turtle it into position and slide it back on. Even with the 4 inch lift. It was alot eaiser without the lift though!
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I just took my full top of on saturday and had one friend help, we just had one inside lift with back the other at the gate and then rest on tailgate so he could get down then walked it to the side of the house and there it will sit! Thinking og letting the wife turn it into a garden and never put it back on! I got the soft top and that seals better anyway just a little noiseier going down the hwy, but hey thats what loud music is for!![​IMG]
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  6. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    What does the top weigh? I've never had mine off, but I need to replace the seals to the cab, so it's gotta come off sooner or later. The "little lady" is just that - 5 foot nothin and 98 lbs. - can't really ask her to help. It would squash her in a second!
    behemoth K5
  7. Burt4x4
    6,854
    Duno if you have a full top or half but my full top is a heavy sucker I would guess a couple hundred lbs. the half top should be fairly easy to do compared to the full top!
  8. behemoth
    May 16, 2000
    1,833
    Northwest Florida
    Half top.
    behemoth K5
  9. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    That's about the same way I do mine, only I get impatient. Another trick that I've started useing, is a peice of old PVC pipe. I get inside the truck, lift up with my back then slide the pipe under both sides. Makes rolling the top back a LOT easier.
    Just thought I'd through that one in.
    Kyle
    89K5
  10. behemoth
    May 16, 2000
    1,833
    Northwest Florida
    ...I'm taking notes here.
    behemoth K5
  11. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    I heard that that the full toppers are around 400 lbs is this true, cause if it is I'm only 140 lbs myself I haven't taken the top off yet but I plan on taking it off soon, I think I will need some help.
    check out my new site, thanks Steve!
    http://chaka73.coloradok5.com
  12. Burt4x4
    6,854
    I don't think it's quite that heavy but it is heavy, too heavy for one person, average person, it's mostly long and awkward to manuver. Good luck
  13. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    I use rachet straps around the rafters in my garage. I place a strap thru the rear window opening and the other end thru the slider window(both sides). I attached the ends snug the straps a little. I then place a floor jack under the rear end, jack the truck up about 6"inches, tighten the straps, then let the jack down slowly and drive out. The reverse is done when I replace it. Plus I can still back my truck in under it at night. Removal and install usaully takes about 20-30 minutes( I take my time)
  14. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    You guys that do it by yourselves must be pretty damn big and strong. If it slides off the side you won't be happy just ask Delta. I needed a co-workers help for the lifting and the wife helped guide it on the bedrails. If I wasn't renting this house I would build a rack for it. Wish someone would buy my 80 parts K5 so I could buy a soft top.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  15. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
  16. 72junker
    72junker Registered Member
    Apr 23, 2000
    66
    atlanta (body) colorado (soul)
    Last time I took mine off I just jumped it without 1/2 the bolts in. Oh yeah, that's why it's in the garage in pieces instead of on the road. Never mind, try one of the other systems.
