one step closer to ECBB
Discussion in 'The Garage' started by boz42, Feb 4, 2005.
  1. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    one step closer to ECBB = 541ci
    just wanted to tell someone, i got my 500 caddy crank back from the machine shop yesterday. offset ground the rod journels from2.50" down to 2.20" to hold 6.8" BBC rods. this changed the stroke from 4.304" to 4.595". indexed, shot-peened, & nitrited the crank. now all i need to do is mock up rods & crank in the block double check the rod hiegth in the blk & order a set of custom Ross pistons. that should take about another 3 weeks to get them. gonna be cutting it close on making it there.:D :D but trying like hell.
  2. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    what the hell is this thing going to put out the end of the crank??????
    and how big is cid????
  3. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i don't understand???
    541.3 cubic inches,,,,, yeh baby!!!!!!!:thumb: :thumb:
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    .....Drool!:bow: :bow:
    Sounds like a killer mill!!
  5. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    4.330" bore x 4.595" stroke:D
  6. sweetk30
    Nov 1, 2004
    25,549
    543
    it want to know how much HP ?
  7. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i really don't know,,, gonna port the crap out of the heads to try to feed it. it will not be enough though, so it will be head limited.
    i have talked to several people who have built them & i hear that i should make between 450-550hp & 600+tq. several peeps w/ this combo say they make so much torque below 2500rpm a dyno can not process what it is, but u know how people exagerate.
  8. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    With a 4.595 stroke the question is not how much hp but how much TORQUE. (alot unless you forget to install a piston or 2).
    I love the caddy motor plan and you are taking it up a step or 2, but you know w/ that bore/stroke ratio its going to rev like a diesel.
    Not that that's a bad thing:)
  9. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    22/7=3.1428571 (pi)
    3.1428571 x 4.33"= 13.60857 (circumference)
    13.60857 x 4.595"= 62.5313 (cubic inches per cylinder)
    62.5313 x 8= 500.25 cubic inches
    What am I missing?
  10. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    my equation for displacement is:
    pi/4 x bore x bore x stroke x 8 = dispacement
    .7854 x 4.33 x 4.33 x 4.595 x 8 = 541.305191566
    u figured the circumference & then multiyplied it by the hiegth. that is not how u figure the volume of a cylinder. both of the equations are below.
    circumference = pi x 2 x raduis
    volume = pi x (raduis squared) x hiegth
    to figure it your way it would be
    cyl. volume = 3.14 x 2.165^2 x 4.595 = 67.6629907202
    67.6629907202 x 8 = 541.303925762
  11. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    I fell asleep in math class. You're right.
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Use a high quality air filter with heavy wire mesh or you're lible to suck smaller particles into the engine.......................
    like jeeps and toyotas!!!!!!!!!!!!!!:eek1:
    :haha: :haha: :haha: :haha: :haha:
