one thing i will like...
Discussion in 'The Garage' started by MTChevy, Aug 30, 2005.
  1. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    about being a member is being able to see attached pictures!!! that really got to me hahah. So im going to go through all the pictures I can. I do have a question too, instead of nonsence. I got tilt steering in my 85. Well, its really loose, like you can lock it in one spot but it will move up and down a kind of big distance. What can this be and can i fix it myself?
  2. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    you need to take the entire steering colomn appart until you find the four little bolts that are loose, remove them and put locktite and titen them back up. it took me 5 hours to do it but the end result is a nice correctly working tilt steering colomn.
    remove!!!
    steering wheel
    clock spring (horn spring)
    colomn lock
    turn signal stock
    tilt lever
    colomn shifter
    ignition switch and rod
    and
    anything else until you get to the four bolts that hold the tilt mechanism together
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Do you use your steering wheel to pull yourself in your truck? If you do, then don't.
  4. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    GM Tilt column fix is in this thread here scroll down to post #5.
    And here is an exploded diagram so you know what they're talking about. The bolts that usually come loose are #41.
  5. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    there is a lot of stuff there! its a manual, so thats a tad bit less to deal with. This kinda scares me! i never needed to pull myself into the truck with the steering wheel but i move it up and down every time i get out
  6. jboyes
    jboyes 1/2 ton status
    Jan 27, 2005
    142
    SE KS
    I learned the hard way about pulling myself up with the steering wheel. It ended up like yours. I tried tightening the bolts but that didn't even work. Worth a try though, before replacing the column.
  7. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    wow, that looks easy. ;) :doah:
