One thing leads to the next and the next and the next.........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Esteban86K5, Mar 16, 2001.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    So I took my tires off to replace my Squeeling brake pads. And what did I find? My rotor has two big grooves in it from the rivets on the pads. Then I found a hub worn out. Then I found the ball joints to e a little to playfull(loose). Then I found my bearings full of water, and finally I found my tie rod ends to be loose also. DOES IT EVER END?????????
    Esteban
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    No! That's what makes it fun.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    That happened to me when I went to repack the bearings [​IMG] Rotors are expensive [​IMG]
    Murphy's Laws on Life :
    "Opportunity always knocks at the least opportune time." [​IMG]
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    yeah, i was taking out my carpet for my herculiner [waiting for 1st coat to dry as i speak] and found a rust hole! bout 1.5 inches tall, and 4 inches wide.
    get the welder out!!!!
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    No, if you're lucky and your truck really loves you then it'll give you a break every now and then [​IMG]
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Check out carparts.com The AR-8400 are vented rotors for my front 10bolt. $54.84. Shawn posted a 25% off coupon, so that should make it easier on you.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  7. dyeager535
    26,979
    Got a question for everyone..if you have a groove or two in your rotor, but its not warped, what do you think about NOT replacing them? With the surface area of the rotor being as big as it is, and the pad wearing down to fit the groove anyways, as long as there aren't many, many grooves, wouldn't new pads alone work ok? I know people are going to say don't mess around with brakes, but remember, they used to use drum front brakes. I guarantee that the disks, even with a groove or two, stop better than that.
    Dorian
  8. Esteban86K5
    3,712
    Bakersfield, CA
    I did that before and basically what happens is you get an enormous amount of vibration when you stop. Some shops turn the rotors for free if you buy the brake pads form them.
    Esteban
