One Ton 14B spring width?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaptCrunch, Dec 19, 2001.
  1. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Anyone know how wide the K30 14B spring perches are? Say from outside perch to the outer side of the other perch? I tried searching for but for some reason couldn't find it. I know they have been posted before [​IMG]
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  2. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Hang on Captcrunch I'll go measure one i got here
    1 ton '87 Chevy SWB in the making!
  3. jwduke
    Aug 25, 2001
    721
    40.5" Center pin hole to center pin hole. This measurement was taken from a 14bolt from a '75 1t.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Outside to outside on my 85. 42.75"
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  5. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Thanks guys, sounds like I'm gonna have to measure a lot closer. Guess this time when I go to look at these axles I better get some scrubby clothes on [​IMG]. I'm thinking it will be one ton though... just my luck I always get the stuff with the "BUT"s.
    -Mikey
  6. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Capt:
    Don't know if it's too late or not but my 14-bolt out of a 1985 1-ton is exactly 40" c/l to c/l; measured with the axle out of the Blazer. The spring pads are 2.5" wide &amp; located 5-5/8" from the back of the brake backing plate mounting flange.
    Hope this helps
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  7. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Captain, My axle is also out from under the truck right now and the old measurements are exactly the same as Brians above and they need to be changed to 42.5" Center Line for the Blazer/Jimmy springs to fit correctly.
    <font color=red> Bill, "Shop Rat" </font color=red>
    http//community.webshots.com/user/bhughes85713
  8. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Thanks guys,,, It was just kinda tricky measuring under the truck so wasn't sure if the measurement I made was right but seems like it is a one ton.
    -Mikey
