OOOOOOHHHHHHHHH EEEEEEEEEEE!! new dana 60 ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCOOBYDANNN, Feb 10, 2002.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    Gonna pick up the 60 tomarrow [​IMG][​IMG] and want everythin to get it bolted up as soon as possible. I've already got the steering block, and spring plates. what size bolts to go in to the one side of the pumpkin and do i get a certain grade? u-bolts? do i need to get new brake lines, where can i find a hub socket for it, can i use the same hub socket for the rear? anything else i'm missing?
    Dan
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, lincoln locked14ff, (soon to be- spooled dana 60, flatbed,and 39.5" TSL's)
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, the front u-bolts will require:
    (2) 3 1/4" i.d. x however long you need x round bend
    (1) 4" i.d. x however long you need x round bend
    (2) 5/8" grade 8 bolts x however long you need
    All u-bolts are a 5/8" rod.
    New brakelines depend on the amount of lift and whether your stock axle now is a 10 bolt front or not. If it's the D44, the banjo bolts are bigger than the D60.
    Hub socket is bigger and different than the rear.
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. SCOOBYDANNN
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    I have the 10 bolt now, so the banjo bolts are the same, where do you think i can find a hub socket? awesome thanks
    ps-you got pm
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Pep-girls, autozoned, napa, any real parts store really. I got a set of hub sockets at the last show for $30, included hub sockets for the D60, D44, and 10b.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
    "JEEP....SO GIRLY, BARBIE HAD TO HAVE IT"
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, you can reuse the stock lines, no problem. [​IMG]
    Hub sockets are found at just about any parts stores. I got all mine from Snap-On. Little spendy, too, at around $35 per socket.
  6. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    you know I just bought a hub socket yesterday as a matter of fact. It was made by OTC and is part # 7158.
    1986 GMC Jimmy 6" springs 3" body, 38/15.5/15 Swampers, 14-bolt FF rear, Dana 60 front, 1991 front-end.
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    What does it take to put a Dana 60 in place of a GM 10 bolt? I have a 1990 3/4 Ton Suburban.
    1. Steering changes
    2. U joints
    3. Spring changes
    4. Brake lines
    What concerns do you have when making the change?
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
    It's a wheelbase thing, you wouldn't understand.
  8. SCOOBYDANNN
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    This is what I've had to buy to bolt it up---
    steering block (like the steering arm for 1/2 and 3/4 ton) but different. spring plates--where the sway bar goes, had to buy from dealer at $53 a peice. and all the stuff Wes listed above
    Dan
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there should be studs not bolts into the cast pumpkin
    formerly 77chev
    still a jerk though
  10. SCOOBYDANNN
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    so nuts go on top instead of bolts going through the spring plate?
    what if for some reason it dosn't have studs? oh well i guess ill find out tomarrow.
    Sun Desert Offroad<a target="_blank" href=http://www.4x4.alloffroad.com>www.4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, lincoln locked14ff, (soon to be- spooled dana 60, flatbed,and 39.5" TSL's)<P ID="edit"><FONT class="small">Edited by SCOOBYDANNN on 02/10/02 11:08 PM.</FONT></P>
  11. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You can remove the studs and use bolts. If you order the u-bolt kit from ORD it will include the 2 bolts you need.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  12. SCOOBYDANNN
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    What does this "kit" do and should i do it. i want to everything right the first time ( unlike the rest of my truck[​IMG])
