Ooops took stuff apart and forgot how it goes back??
Discussion in 'The Garage' started by CaveBlazin, Apr 10, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok Im putting the bearings and other little things back in the hubs but cant remember which way the bearing face and in what order the things go. HELP!! Sorry yes i should have wrote it down.. /forums/images/graemlins/dunno.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you are talking about front axle then the bearings will only sit one way in the races. Inner bearing should have the larger side in tapering out to the smaller. The outer should be large side out tapering in. Then you have hub nut, lockring, hub nut.
    Harley
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Oops I mean on my 14ff /forums/images/graemlins/whistling.gif
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't remember about that one. I didn't do the bearings in it last time around. You should be able to see which way the bearing go in by looking at the races. the races are tapered to match the bearings. The only real way the bearings could go in though I think would be taper inward.
    Harley
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
