oops?! how to remove a broken bolt!?!?!?!?
Discussion in 'The Garage' started by mrpoorboy, Oct 2, 2005.
  1. mrpoorboy
    mrpoorboy Registered Member
    Feb 21, 2005
    84
    hillsboro, oregon
    i broke a bolt off reinstalling my valve covers. obviously, i was not paying attention. drivers side off the sb 350, top left. any suggestions on how to remove? any help would be greatly appreciated. thanks
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Drill a hole in the center of the offending bolt and use an easy out. :D
  3. FreedomIsntFree
    FreedomIsntFree 1/2 ton status
    Aug 23, 2005
    124
    DFW, TX
    What he said.
    I think an easy out is the same as a screw extractor.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive had no luck getting broken valve cover bolts out. they are 1/4" and hard to drill in the center. did it break off flush?
    what i sometimes do if i can't get it out is weld a old wrench or vice grips to the top and unthread it. if there isn't enough room to go all the way around with a wrench, i build up the weld on the top of the bolt and make it like a t and then use a small wrench or pliers.
    with the valve covers, that would be my last choise because of the open springs and such. if you did, take a small damp towel and lay it over the springs and leave enough room to weld.
  5. mrpoorboy
    Feb 21, 2005
    84
    hillsboro, oregon
    it broke just below flush. went to parts store and bought a couple screw extractors. hopefully that works. if not, off to the machine shop. i have no welder, which lately, has become a problem. thanks for advice.
