Open element air filters
Discussion in 'The Garage' started by pplblazerdude, Jan 25, 2004.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    If i put a open element air filter would it more pron to pull water in the the stock one. I do some mudding nuthin to deep. And also those k@n wrap things for the dirt will they help with water if it gets sprayed up that way so my engine doesnt suck it in.
    clint
  2. dyeager535
    26,982
    190
    Open element is *probably* a little more likely to ingest water if you are throwing it up with the tires. (running through pits and what not)
    Stock type can have a problem if you get water up high enough that it completely covers the air inlet. As it's set up though, the air inlet on the core support isn't much lower than where an open element would be, so the difference isn't going to be huge.
    If you don't plow water/mud with the upper part of the core support, the stock snorkel should be more than adequate. You make more power with cooler air, open elements don't have that benefit. You can always "dual snorkel" the stock air cleaner setups, since the factory core support (at least '81-86) used a drivers side inlet for the I6 motors, which is a knockout piece on V8 trucks.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    In my experience, open element filters are less desireable for off roading. I initially ran a 14x3 open element K&N. It got dirty FAST. I later came across a 14x5 air cleaner off of a Blazer. I installed a 14x5 Amsoil 2 stage oiled foam filter and could not be happier with it. Foam stops the most dirt, then paper, oiled cotton is last.
  4. pplblazerdude
    Jul 18, 2002
    242
    so are you saying if i put one of the kan pre filter wrap thingys on it will help.And would a k@n filter be good for this setup.
    Clint
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The pre wrap will help. I know when I used to mud race, I pretty much ruined a filter with every event. The pre wrap might help it shed water. I know I was thinking of putting on a closed element just for filter protection.
  6. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I have been running a 6" k&n for a while and have never had any problems with water or mud. The last time i was out wheelin i had water 2" up on the element and it didnt suck any water into the inside of the element. I do however clean the element after every trail ride. This keeps it clean and i think it keeps the element oiled up and repelling the water.
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I have a open K&N on my truck and have had NO problem at all, But I run full innerfenders. I also have one on my 4wheeler along with a pre wrap and it helps repel the light water and keeps a good amount of loose dusty sand out
    My prefilter was one of those thin black ones they also have the foam ones that might help alot more if your just covering your filter in mud and water
  8. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I just started creating an airbox tonight. It will be able to hold any diameter element up to 14" diameter. 3" tall elements only. Hopefully in a couple days pics will be posted.
  9. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    sorry for the highjacking question but for those that are running closed elements where are you running the hoses to? If you run it too the front you risk water injestion and if you run it to the fenderwells you're picking up dirt so where else?
