Open element to fit TBI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blackdog, Sep 6, 2001.
  1. blackdog
    blackdog Registered Member
    Aug 8, 2001
    98
    New Jersey
    Is there an open element air cleaner that will specifically fit over the throttle body on an '87? Nothing seems to fit right (won't clear all the stuff to settle down low enough) and no one seems to have one listed for this application.
    <font color=black> "Where did all these people come from, and how soon can they leave..."
    -OLD 97's</font color=black>
    <a target="_blank" href=http://www.k5.batcave.net>www.k5.batcave.net</a>
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Simple solution. Go to a junk yard and pick-up another spacer that fits between the air cleaner and the TBI, stack them, close up the egr hole and it will work fine. They do make tall spacers, but they are pretty expensive.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  3. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    I had one that was actually made for a Q-jet I put on my Dad's 88 TBI 350. Fit fine. I think it was a Moroso. I got a taller filter and longer screw too for the wingnut. It was cool cause you could hear it sucking in the air when you wound her up.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I'm running K&amp;N's on both my k5's (they are both 89's with tbi's...)
    on Jedi Mind Trick (on-road k5) I'm running K&amp;N with the extreme top, and on Insane Ewok (off-road k5) I'm running a K&amp;N with the pre-filter &amp; solid chrome top.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  5. blackdog
    Aug 8, 2001
    98
    New Jersey
    You wouldn't happen to know which model K&amp;N it is, do you?
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I'm running an open air filter on my TBI. Don't know the model number, but it's a 14x3 inch K&amp;N.
    Bubba Ray Boudreaux,
    Leader of the Advance Party for
    the CSA revolution in the PRK!
    <a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    it is just a standard 14" K&amp;N... got a least 3" on the filter...
  8. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    What has running an open filter on a tbi done to your gas mileage?
  9. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    you know I have no idea... I don't really track my gas milage...
    both my k5's had all the tubing etc. pulled so it was the stock setup without connecting to the front. I figured if I'm gonna be sucking hot air then I might as well as suck all the hot air I want... LOL
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    nothing really. It added a little power, but that's about it.
