Open Knuckle, Closed Knuckle???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Biguub91, Dec 15, 2002.
  1. Biguub91
    Biguub91 Registered Member
    Nov 25, 2002
    33
    Texas
    What is the difference between open and closed knuckle noone has ever clarified this for me? How can you tell any info or links would be great.
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    An open knuckle design is the type of front axle where the U-joint's are clearly visible at the end of the axle tubes on the knuckle's. Every live axle today is a open knuckle design...A closed knuckle design is where you cannot see the U-joint; instead, you they are inclosed. These axles are not made anymore and can be found underneath old Power Wagons, Kaiser's and M-37 and 60's and later 4x4 trucks.
  3. Biguub91
    Nov 25, 2002
    33
    Texas
    thanks alot it was alot simpler than i thought
  4. Grim-Reaper
    7,385
    Atlanta
    When hunting for axle always look for 74 or newer. 73 and older D44's ran a smaller u-joint in the front at the knuckle.
