open or closed in 69 and 70 ?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by R72K5, Oct 30, 2001.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ot a dilemma over at 67-72chevytrucks site, need to know for sure whether all 69-up fornt axles are open knuckle or not. I couls swear all are open after 68,
    Or are they not til 71 ?!
    '72 K-5 4x4, CST, 3.07, 4 speed, NP 205, 31' x 10.5", converting to 2wd and pickup body(I did not want to do this- rust made me do it)
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    I have a 70 with a open knuckle D44 with drum brakes. I don't know if it helps, but thats what is in mine and it is for sure stock.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i assum 69 are open also, thanks !
  4. My 69 K20 has the closed knuckle Dana 44, heavy duty version. I'm pretty sure the change over came at the end of the 69 production year.
    1969 C20 4x4
    4" lift, 35x12.50x16 Super Swamper SSR's
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what did the HD option consist of anyways, I have seen the option listed in the Chevy truck data sheets from GM, but never knew what axle it was ?
    thanks
  6. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I think the '68s are closed, the '69s came with both &amp; 70's should all be open.
    Never said I could spell!
    '70 K-20 San Diego, CA
  7. Randy, the HD front axle was different from the K5, K10 Dana 44 due to 86x u-joints and two-piece, six bolt drive hubs. The K5, K10 Dana 44 used 74x axle u-joints. Both axles were 1.31 diameter and 30 spline and both used the 8.50 in ring gear. The above info came from a great article in the March 2000 issue of 4x4 Power which is no longer in print. I've got it scanned if you want a copy. It is titled 4x4 Blueprinting "Classic 'Burbs and Blazers" and gives stats for the different engines, tranny's, transfer cases and axles for 67-91. The missed the ball on the transfer cases though cause they left out the Rockwell T-221 that is in many of the 67-69 Chevy and GMC's. Good to see you on this board.
    1969 C20 4x4
  8. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    could I get a copy of that scanned article as well please?
    thanks bud
    Les
    Like em big and topless
    Excuse me...Would you mind removing your import from under my chevy?
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would like a copy too. If you send it to me I will put it up on my website.
    triaged@earthlink.net
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  10. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
  11. I'm e-mailing the article to Triaged and he will let everyone know when it is on his site for viewing/downloading.
    1969 C20 4x4
  12. Triaged has it posted in a separate post "Blazer article" Thanks for getting it posted.
    1969 C20 4x4
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Addy to the site ?!
    What addy to the site ?!?!?
    Thanks fo rth einfo !
  14. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: Addy to the site ?!
    I don't have a link to them on my website but here are the links.
    <a target="_blank" href=http://home.earthlink.net/~triaged/Blazer_Article/chevyarticle1.jpg>Page 1</a>
    <a target="_blank" href=http://home.earthlink.net/~triaged/Blazer_Article/chevyarticle2.jpg>Page 2</a>
    <a target="_blank" href=http://home.earthlink.net/~triaged/Blazer_Article/chevyarticle3.jpg>Page 3</a>
    <a target="_blank" href=http://home.earthlink.net/~triaged/Blazer_Article/chevyarticle4.jpg>Page 4</a>
    <a target="_blank" href=http://home.earthlink.net/~triaged/Blazer_Article/chevyarticle5.jpg>Page 5</a>
    <a target="_blank" href=http://home.earthlink.net/~triaged/Blazer_Article/chevyarticle6.jpg>Page 6</a>
