Opened up spring clamps....big difference in flex (Bad for springs???)
Discussion in 'The Garage' started by Flexy K20, Dec 1, 2002.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I opeaned up the spring clamps that keep all the springs together and it made a huge difference in flex. I just bent them up in a U shape so the srpings will stay in place but when the axle droops the leafs can seperate. I was just curious if this is bad for them? I know you can hyper extend springs but just in general because at full droop only one leaf is holding the axle up. They are Superlift 4" springs if it makes a difference. Thanks for the help
    -Flexy
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i know a lot of people do it,but i think that after a while it will take some strength away from the springs.mine was like that when i bought it and i took a hammer and bent them back.i just dont like the way they flex way out and open up the spring pack so much.
  3. FULLSIZE
    FULLSIZE Registered Member
    Aug 8, 2002
    76
    i always use this saying when i'm doing a mod:
    "i'd rather be stuck then broke and stuck"
    the amount of flex gained isn't worth the breakage. the main leaf will eventually break at the spring plate. maybe you'll be lucky, thats just been my experience. /forums/images/graemlins/cool.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm with everybody else here...
    I don't like the idea of having the clamps opended up all the way because of the added stress it puts on the leaves.
    Do not do it (in the front) if you don't have crossover. You will kink the leaves for sure.
    I don't mind loosning them up a bit so the springs can move a bit (a very little bit)...but don't make them a "U".
