opinion on gear ratio
Discussion in 'Plains Region' started by fourwheelerjeff, Oct 14, 2002.
  1. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    hey guys, i have an 88 blazer that i am going to swap in a 3/4 ton set of axles, would you go with 4.56 or 4.88 gears, i will be running 38 inch tires or so, 6+3 inch lift, with locker front and rear, although this will mainly be a street and light wheeling rig, i really don't need the lockers but since i have them, why not?
    opinions /forums/images/graemlins/1zhelp.gif
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    You asked for opinions, so I will give you mine:
    Don't put on a body lift. 6" is plenty of lift to clear 38's. You could clear 42's with that, I only have 7".
    Put the 4.88's in. I wish I would have gone with 4.88's, and I run 35's on the street.
  3. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    but i really don't want to cut the body
    i will cut the body on the 79 or 83 they will be for wheeling, with one tons and 39.5's
  4. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Well, since your just using it for light duty trail use and on the street, it would be ok. I am just not a big fan of body lifts.
  5. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    4.88 all the way. You'll love the take off power you will have with the 4.88's /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gifJust don't expect great fuel mileage on the open road /forums/images/graemlins/rolleyes.gifjust my .02.
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  6. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I'd go with the 4.88's and the 6"+3" lift. I've got a 6" lift on my blazer with 35's right now and they hit all the time and my fenders are trimed all the way to the firewall.
  7. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    My guess is your tires rub due to the 14" rims. But it looks like you have wider than 12.50 tires too.
  8. fulltopblazer
    Aug 1, 2001
    484
    Yea thats the main reason. I kinda regret buying the 14" wide wheels, but at the time it sounded like a good idea. I'm going to 39.5 boggers and they are like 18" wide so I thought the 14" wide wheel would be good.
  9. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Just because the tire is stated at 18 wide does not mean you have to run that wide of a rim. You could probably get away with a 10" wide wheel with out popping a bead. I'm going to run the 39.5x18/16.5 bogger on a hummer beadlock wheel and they are on 8.25 wide, but they lock both the outside and inside bead. /forums/images/graemlins/thumb.gif
    Just thought I would throw that out there.
