Opinion on this 350
Discussion in 'The Garage' started by hunterguy86, Apr 18, 2007.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I'm thinking about picking up a 4 bolt main 350 that has been bored .30 over. The block and everthing seems ok except for one cylinder. The valve spring broke allowing the valve to fall down into the cylinder and make contact with the piston. Even though that cylinder was not working properly, the engine still ran great. Pics of the piston are below.
    Also I would guess that since the valve spring broke I need to go through the heads. Would it be cheaper to rebuild the heads or get a set of new ones?
    I found these heads on summit. Would they be good for a mudder/DD?
    How about this for an intake?
    I'm sure the cam got trashed when the valve spring broke. How about this for a replacement cam?
    Here are some pics of the piston.
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    slap on some vortec heads and call it done.
  3. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Any thoughts on the links to the parts I posted?
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    the heads, intake and cam look good. Maybe one of the desktop dyno guys can plug it all in for you. Should be a nice mild motor
  5. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    so it would be ok to run it with the piston like that? I know the damage isnt that bad but would it weaken the piston any?
  6. resurrected_jimmy
    May 23, 2005
    2,241
    it does weaken the piston but he is not looking at a high performance build. It should be alright.
  7. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i'd say if you're pulling the heads, anyway, replace at least that one piston while you're in there. it would just be more hassle later, when it had to be done anyway. it's hard to see just how bad the damage is from that pic, but it could cause stress risers or allow uneven heating on the metal.
  8. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Where did the broken valve head go? Into the head?
    The heads, intake and CompCam look good.
    I would recommend dis-assemble the whole engine, clean, inspect and reassemble with old parts that are serviceable = replacements and new gaskets, etc.
  9. Bo 84stepside
    Bo 84stepside Newbie
    Apr 17, 2007
    San Marcos, TX
  10. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Good price!
