Opinions on brakes for my 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KevinsK5, Sep 3, 2006.
  1. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    I pulled the drums off my junkyard 14 bolt today to see what the brakes looked like, to see if they were useable. They're not, both drums are scored real deep on both sides. I think turning is out of the question.
    So I made a call to napa, and new drums (11") are $117 each plus new shoes and hub seals. I remember seeing a 14BFF disc kit on E-bay for $299 without an e-brake. I'd like to keep my drums to have an e-brake, but I don't want to wipe out new drums with sand and water. I'd like to have discs in back for good stopping power and self drying/cleaning, but no e-brake might suck.
    Both options have one big pro and one big con. I'll say my budget is $300 either way. What do you think? Thanks, Kevin
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I would do a disc swap. Rotors are $50.00 each, disc brackets you can get for $50.00 and the calipers are what will cost the most if you want to retain an e-brake. Not sure on caliper pricing but somewhere around $75.00 each with a core
  3. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Caddy Eldorado rear calipers for Parking Brake. Year 78-79? Look in the vendors forum for disc brake adaptors. One of them will certainly have the info you need. I'm sure you can get 'em for less than $300. Probably could go with slotted discs and still be under $300;)
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Caddy eldo calipers are 76-78 only.
  5. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Quick check with JC Whitney shows 78 rear Caddy Eldos at $113ea for rebuilt:rolleyes: Looks like junkyard would be best bet.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Good luck finding any.
  7. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    If you are interested in finding those Caddy Calipers I can have my local wrecking yard buddy check for you. Let me know and I can do it on Tuesday if you want the help. PM me today or tomorrow.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is a pair for sale in the for sale forum right now.
  9. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    depending on your transfer case you can get an e-brake that is mounted on there. I bought plans for the brackets on e-bay for $8 plus shipping. I made several sets of brackets at once if you need a set. I run dana 44 calipers without a parking brake. I'm offorad only though.
  10. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    don't even bother with the caddy calipers. tried 'em and they sucked.
    either keep your drums or go with some 10b/d44 calipers and a driveline brake.
  11. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,236
    284
    San Jose, California
    I am almost done with the disc swap and used 79-85 caddy calipers with e-brake. They're hard to find new, but wrecking yards have them pretty cheap.
    I like the TSM kit, it was really well made.
  12. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    What's the difference between 76-78 vs 79-85?
  13. bp71k5
    Mar 31, 2006
    6,236
    284
    The older ones fit larger discs I believe. The disc in the rear of cars are usually smaller since they don't do as much work.
  14. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    I'd be very interested in going that route, but I'll have to do some searches on it unless one of you wants to learn me all about that style e-brake. I know nothing about them as of right now. I'm using a fixed yoke 205 in my truck. Thanks, Kevin
  15. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I believe that High angle Driveline makes a E-brake for the 205.
  16. GMCJason
    GMCJason 1/2 ton status
    Dec 23, 2004
    242
    Longmont, CO
    Here's what HAD has to offer. http://www.highangledriveline.com/e_brake.html
    I'm in about the same boat myself right now. I'm building the 14bff for my Suburban and want disc brakes but really don't want to lose the emergency/parking brake. I haven't heard good things about the Caddy calipers and I have a 241 (for now) with the slip yoke so I can't use the driveline brake without some other good-sized mods.
    I really haven't done any searches here or anywhere else for the driveline brake so I can't help much. Good luck with it.
    Jason
  17. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    Ditto. I checked that link out (thanks), and that route sounds very appealing right now. Though it will prolly be 4-5 bills when all done, I would imagine it'll pay for itself the first time I need it. But for right now, it's just one more thing that reuires $400 to make my project functional. I'm sick of throwing money at this truck, at least for a while. Thanks, Kevin
  18. 1crzy88
    1crzy88 1/2 ton status
    Sep 7, 2004
    119
    NOR Cal
    If you don't mind me cutting in... just do the disc conversion, (i rec sky's $95 for the brackets. ) i love mine) and do the e-break later when you have more $$, i ve been running no- e break for almost two years now with great luck. in the prosess of the 205 w/ drive e-break. i was in your same boat with the $$$. But you should do the disc swap, you'll thnak yourself later.
    T
