Opinions on Crate Engines
Discussion in 'The Garage' started by djsblaze, Jan 20, 2004.
  1. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    Just planning ahead. What crate engine would you all recommend for an 89 with 4.88 gears and 38's. I am looking for reasonable power (250-300 HP) and durability. Of course, I would love a Ram Jet 350, but its not in the budget. I was leaning toward a GM crate, but a mechanic buddy of mine really likes Jasper Engines. Does anyone have experience with Jasper engines? I know they make a fine NASCAR engine, but thats not what I am in the market for. Penny for your thoughts, and thanks in advance.
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Ive owned a couple of GM crate engines.
    Hard to beat for the price.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i got the GM Goodwrench engine (285hp IIRC)
    happy with it. underpowered for the weight of the rig, but that is what gearing is for, and I've not been able to get mine tuned right. once i spend a weekend on it, it'll be great.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    What kind of warranty do the Jasper engines have? IIRC, the crate engines have a 3 year - 36,000 mile warranty?!?
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    In the mechanical shop I worked in...
    we used tons of those Jasper Engines..
    and had NO problems...
    I have a GM zz4 that I bought in 99'..
    I've beat the crap outta that motor..
    It still screams!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    the truck 383 looks pretty sweet.. thats what i'd be looking at...
    we used to alot, and still do on occasion use Jasper's for our marine apps at work.. mostly good to say, the 350's where usually rock solid.. but we did get a couple of 440's done by them that grenaded in about 10 hrs.. their fault and they warranteed them... i think alot has to do with the Jasper in your area, might wanna check out their local reputation...
    my .02
  7. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I've got the base model GM crate 350 motor in my Jimmy and I haven't had no problems or power issues! Great motor!
    Bill
  8. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
  9. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    This is what I would get. http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=120&pid=117
    I believe Mudzer has a Jasper motor in his K5.
    If he could afford that, he could probably buy the Ram Jet 350 possibly. I think from reading his post, He is looking for something under $3000.00 probably around $2000.00.............Dunno though cause he didn't specify a price range /forums/images/graemlins/confused.gif! Although I liked that motor too , But can't afford it either /forums/images/graemlins/frown.gif!
    Bill
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think the brand new $1300 motor is the best value. I might consider one if my current engine ever quits.
    I am thinking about doing my top end next summer or fall and then building a short block in the future too. That's one other way that if your engine isn't worn out you can do quickly.
  11. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    A few years ago I bought a new chevy "m" sieries motor for my 1ton 9000lbs work truck .The motor was suppose to be heavy duty with stronger bearings and a low end cam for towing .I put aprox 30,000 miles on it and it ran like a top...I think I payed 1800.00 for it 5 years ago ..
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you are planing to keep your TBI. Make sure you get an engine built to run with TBI.
    Not very many crate performance engines will run with TBI without getting some chip work done and a larger TB.
  13. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    I bought the 454 H.O. crate engine from chevy.
    Great motor,be sure to pull the pan on any crate motor as I found out the hard way,,,there was cardboard and plastic wrapping material in the pan,,,no oil pressure upon start up.
  14. djsblaze
    Jul 7, 2003
    318
    Oklahoma
    Thanks gang. I know I was not very specific on price range, but someone nailed it, Im not looking to spend more than $2500 ish. Id love the Ram Jet, or similar setup, but looking for more bang for the buck. I appreciate all of your comments, I'll probably just go GM to avoid any problems. I just didnt get enough feedback on Jasper to overrule the General. Thanks again.
  15. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    rated at 260. which is a total joke. probably about 300hp right out of the box, stock manifold and carb. I got one. with 3.73s making a right turn i can light the tires up and cut it sideways NO problem at all. that's with 39x18" tires. . . tons of low end too! my carb coughs with the secondaries and it feels like a small shot of nitrous. i CANNOT wait to put in roller rockers, aluminum intake, edelbrock carb, and a 268HE cam.
  16. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I ahve used jasper engines. No probs with them. but, I would lean towards the GM crate engines. better warranty.
    I have bought engines from Scoggin dickey also. great service. I used to buy LS7 crate engines(when they still had them!) Got great deals. Cheaper shipped from them than the discounts we got at GM!
    how about this one
    or stock, use the money you save on some performance upgrades
    stock reman
  17. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I have the 1300$ 260 hp 350 ftlbs, 3 yr 50k mile warrenty engine. I have about 4k on it now and besides it finishing off my trans I love it. I never would have thought 260 hp would spin 35s though 308 gears. IF you want the tbi then go with the sdpc tbi motor.
  18. 2bhntn
    2bhntn Registered Member
    Jan 16, 2004
    12
    Flint Hill, Mo
    I have a Jasper rebuild. All their engines are built in Indiana. They don't have local rebuilders that I know of. Here is there webpage http://jasperengines.com/ . Warrenty on my 5.6 was 75,000/3years. Runs great, put approx 50,000 on it by now. Also put a Jasper rebuild in my old Ford Ranger 4x4. It had 120,000 miles plus when I sold it and it still ran great. I spent close to 2500$ with new distributer, water pump, hoses, belts, plugs and wires, etc.
    Good luck
  19. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i got a 3.4 crate in my s15 , 15,000 miles and still
    going good.
  20. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    what does sdpc mean?
