Opinions on engine knock/rattle
Discussion in 'The Garage' started by Cricket, Apr 12, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    1977 350
    Stock with badger flat top pistons, elgin cam eqivalent to edelbrock 2102. No other internal mods. External mods are headers, edelbrock intake/carb.
    I have developed a knock/rattle that sound like a spray can when you shake it extremely fast. Only very audible when engine is cold in the morning. When I start the truck I get a quick rattle like a lifter is pumping up then it becomes quiet. You won't hear it again until you drive away and put a load on the motor, more gas = rattle, let of pedal and it disappears. When warm you can only hear it if you are me, it is so inaudible you have to know what you are listening for. It's coming from the passenger bank 2/4/6/8
    Oil pressure has always been good, 55psi at cruising, 18psi at idle. No fluctuations in the gauge, no overheating, does not use oil, no oil out of exhaust. Oil is clean, no water, no gas, no metal.
    It is very slowly getting worse over the months. I've always though it was the piston pin. Anyone else have any other ideas, I'd appreciate hearing them.
    ADDY: MSD ignition, timing is not overly advanced ie. spark knock.
  2. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Sounds like rod knock to me. 18 psi at idle is good but a little low for a healthy motor. Drop the pan down and pull some rod caps off, if you see any copper.....crank kit time.
  3. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I'm gonna add my 2 cents and say that a piston pin could also be the culprit.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    A noise or rattle when you step on the gas is detonation. You might need to play with the timing and or run premium fuel. I would start by filling up with premium fuel and see if that helps the noise. If it does you are experiencing detonation for sure. Playing with the timing might make it go away. I have no idea what compression ratio you are currently at right now but anything over about 9.3/1 and lincorrect timing or low octane fuel and you will have detonation problems. You may need to address both timing and higher octane fuel to make the noise go away.
  5. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    10 psi per 1000rpm is adequate....excessive oil pressure is just wasted HP
