Opinions on holley TBI adapter plate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Apr 1, 2003.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I was gonan use an adapter from holley to put my TBI on my edelbrock intake on my 84, But I thought I saw someone saying that it's a bad idea to use the adapter. I tried searching for it, but I couldn't find anything on the post. So what's the general concensus on this thing? /forums/images/graemlins/confused.gif
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im interested in this also, Holley recommended using their adapter over using their TBI intake? Anyone with experiences on this?
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Heres a couple of snips from an article on this site http://www.goingfaster.com/spo/modthel03.html
    which talks about hot rodding 2nd gen camaros with 305 TBI.
    <snip> A TBI spacer fits directly under the TBI unit, on the manifold itself, and raises the injector above the manifold, increasing air flow and velocity, thus increasing power. You might even be able to put two spacers under your TBI unit, depending on hood clearance problems. One should do you just fine. Another cheap modification ($20) is a TBI injector spacer. This 'other' spacer raises the actual injector housing within the TBI unit, creating air flow increases of as much as 7%! Again, you may be able to use a second injector spacer to make even more flow increases depending on hood clearance problems. It's your call based on what type of hood you use, stock or aftermarket
    <snip> Holley makes an adaptor plate which allows you to use your TBI unit on any manifold that will accept a four barrel Holley carburetor, which is 99.9% of all aftermarket manifolds out there. This allows you to bypass the restrictive intake passages all together and go with a more conventional manifold design such as the Edelbrock Performer series or the Weiand 'Stealth' series of manifolds.....Here is a pic of the Holley unit, part number 17-45 and is available directly from Holley. Using the adaptor plate, you could use the 670cfm Holley TBI injector with one of Holley (or another company's) four barrel intake manifold...........use the 'four barrel' intake manifold and a TBI adaptor plate to install the TBI unit to the manifold. This offers the biggest intake area for the air / fuel mixture. Turbo City and Holley both make adaptor plates so that you can mount your factory TBI unit (or the 670cfm Holley unit) to any manifold which will accept a four barrel Holley carb.
    sounds like a good idea to me /forums/images/graemlins/thumb.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    If you want to go on the cheap, GM made a stock adapter for a few years. They can be found on truck around 91 or so with a Big Block. Instead of trashing a ton of four barrell manifolds, They just used an adapter untill the manifolds ran out. They were set up for water cooling but I just didnt hook mine up. Spent $2 for it at the yard.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    OK, that is fine, but when is the last time you saw a big block, let alone a TBI one, in a junkyard????? In all the years I've been going to junkyards, Ive seen three, in Colorado, and those were 75 and older. My 89 has that spacer on it, and has the same intake as my 82 454.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Use the adapter plate. They work fine. The only problem with them is if you are running a 700r4 tranny. You may have to modify the TV cable mounting a bit to get it to work right. Or get a TV made easy kit from http://www.700r4.com
