Opinions on homemade receiver shackle bracket
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jarheadk5, Jul 1, 2001.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I recently "appropriated" a couple of big-a$$ shackles/clevises, and the pins fit almost perfectly in my receiver bracket that had my hitch ball on it. It's one of the brackets that has almost no lift/drop, so the pull forces will be almost inline with the receiver, not above or below. Is this a good idea? Seems much better than $40 for almost the same thing, just pre-made.
    BTW, I know about putting the loop right into the receiver and pinning it. I don't like doing that.
    If at first you don't succeed, failure may be your style...
    [​IMG] Semper Maintenance!
  2. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Absolutly, that is the same thing I have been doing for years. The only difference is mine is a fixed mount. It doesn't look as nice and it rattles more, no biggie to me. The limiting factor on yours and the one you buy is still the hitch pin. Just keep that in mind.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    That's what I've done forever with no problems the only thing I change is that I've got a nice, burly Grade 8 bolt I use as a hitch pin for that purpose, and a standard pin for towing.
    If it weren't for bad luck, I'd have no luck at all[​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  4. jarheadk5
    Mar 6, 2000
    4,389
    PA
    You're talking about the pin that holds the bracket (removable part) into the receiver (bolted-to-truck part), right?
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Right - it's a 5/8"X3.5" bolt - nearly indestructible.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Fine idea. The 73 I just bought has a reciever hitch and I was trying to decide what to do for a rear tow point. That sounds like the ticket. I just don't have faith in those pins. I am sure there is nothing wrong with them but they just don't give me a warm fuzzy.
    Jim '80 GMC
    Freedom First!
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got the Warn bracket, others use a clevis and a trailer hitch, same thing either way.
    Tim
