opinions on "new" bedliner products
Discussion in 'The Garage' started by mastercraftkpk, Feb 25, 2004.
  1. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    opinions on \"new\" bedliner products
    I have poured through the search results to no avail.
    Has anyone used the products Gator Guard II or the SEM catalyzed Eurethane bedliners?
    Gator Guard II is an epoxy (although it says it stays flexible in low temps), and I was thinking of putting it in the engine compartment on the firewall. Haven't done the research re: flamability.
    Also thinking of using it on the interior. It claims to be durable, figured that it would be tougher than Herculiner but cost less $$ than Line-X/Rhino because I can DIY.
    The SEM is a catalyzed Eurethane that should also be durable and could be put on thicker that the Gator Guard, but not in the engine compartment because it likes to burn.
    Are either of these getting closer to the quality of the professionally applied products?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: opinions on \"new\" bedliner products
    this should be in the garage so I'm going to move it there /forums/images/graemlins/thumb.gif
  3. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    i used herculiner and it worked good
  4. mastercraftkpk
    Mar 12, 2003
    192
    Houston, TX
    Good example of why I posted it in the member forum as I originally did, but thanks for your "help" in re-routing, the info gained has literally been invaluable.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I just put 2 quarts of Hurculiner on the Blazer last night and I cant get the stuff off of my hands. Looks good drying in the garage.
  6. Re: opinions on \"new\" bedliner products
    Use acetone to clean it off your hands, tools, etc... but its probably too late if its completly dried. I had the same problem last year, ruined some shorts and shirt.
    Mat
  7. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You sure are whiney. /forums/images/graemlins/1zhelp.gif
  8. mastercraftkpk
    Mar 12, 2003
    192
    Houston, TX
    Thanks for your "input", it continued to help me re: the bedliner products.
    /forums/images/graemlins/waytogo.gifYou are part of the heart & soul that makes this site great. /forums/images/graemlins/waytogo.gif
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You don't make friends very well do you? This site is a great source of info but only if people volunteer their knowledge to you. So, when you piss people off, you don't get answers to questions. I originally typed a good sized paragraph but decided that this little guy sums it up: [​IMG]
  10. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  11. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Oh, sorry, whiney AND sarcastic /forums/images/graemlins/peace.gif
  12. mastercraftkpk
    Mar 12, 2003
    192
    Houston, TX
    It certrainly does sum it up. You divulge more than you realize.
    Go ahead and keep your valuable info to yourself. It has probably gotten you this far, so....enjoy.
  13. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Keep on truckin, Kaiser... /forums/images/graemlins/thumb.gif
  14. 78k20
    78k20 Registered Member
    Feb 28, 2004
    53
    Eastern Washington
    MasterCraft-
    Sorry to ruin the fun, but back to the bedliner stuff... I can't speak for the two you mention, but as for the toughness of the Herculiner, I've had great results on my trailer with it. I Built a small 5x10 single axle for hauling my AC 500 Auto, and elk hunting gear on, and got very tired of repainting the thing every time I drove it on any kind of gravel roads. Broke down and bought some of that Herculiner stuff, put two coats on over the entire thing-except for the bed-and it's held up great. That was a coupe years ago now, and have had to put new tires on the trailer since, but the Herculiner is still in great shape-even over countless miles of gravel roads.
    Hope that helps, and Best of Luck,
    Mike
