Opinions on running a 35" tire on 10" wide rim...
Discussion in 'The Garage' started by 1-ton, Nov 7, 2004.
  1. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Opinions on running a 35\" tire on 10\" wide rim...
    I am want to buy a new set of 16" X 10" rims for a set of 315/75/16 tires, but all the manufactures of 315/75/16 (35/12.5/16) tires recommend 8.5" wide rims for this size tire. I think 35" tires look funny on 8.5" wide rims...like balloons bulging out at the sidewalls. What do you people think about running 35" tires on 10" wide rims?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Opinions on running a 35\" tire on 10\" wide rim...
    If you don't ever have any intention of airing down it'll be fine.
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    This truck will only be used for camping, hauling dirt bikes, and towing. The only wheeling this truck will see is just enough to get out to the campsite.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Can't you get tires that are 14.50 wide ?? They work very well on 10" wide wheels.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    So do 12.50s and they look better.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Wider always looks better. And you can still air down if needed on a 10" wide rim with a 14.50 wide tire. But then again, I use 15's instead of 16's.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The load range on 15" tires sucks, it would be completely stupid to put 15" tires on a 1 ton that you were going to tow with.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Okay, where does he say anything about 1 ton or towing ??? [ QUOTE ]
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Right there Z3PR.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Right there Z3PR.
    [/ QUOTE ] Okay, but I'd still use a 15" steel rim and do some caliper gringing because of lower tire prices.
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have 35x12.5r15 on 15 x 10 rims, and i have had no problem at all. ive aired down to 5 psi and the bead still held, even did some donuts and still didn't loose a bead.
    my 265/75r16 BFG have a load rating of 2778, my 265/75r16 Goodyears are 2601, and my 35x12.5r15 dunlop are 2555. not that much difference, they are all load range C though, but you can get higher in a 16" tire and i dought it with a 15" tire.
  12. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    i used to have my street tires (35x12.5x15 procomp MTs) mounted on 15x10 rims. I switched to 15x8. Honestly, I don't think I ever noticed a visual difference. Im sure there was a little, but its nothing to wet your pants over. Go with whatever is cheapest and will fit over your brakes.
    j
  13. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I have wheeled 35-12.5s on 10" rims for years never had an issue.
  14. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think that Ground Hawgs are the best tire for.... oops, wrong post! /forums/images/graemlins/histerical.gif
    I don't think that you will notice a lot of difference in how the tires will look on either size wheel. I would run the 10 inch wide wheel though so that it will bring the tires out to the edge of the fenders instead of keeping them tucked under.
  15. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I ran 35's on 15x10 Alcoas on my Bronco aired down all the time and also had no problem. I plan on 16x10's with 315/75r16's for the Blazer shortly.
  16. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've run both 11.50's & 12.50's on a 10" wide rim for years without any problem. /forums/images/graemlins/waytogo.gif
  17. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Where's rjfguitar when you need him.....? /forums/images/graemlins/histerical.gif
  18. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    This is an opinion post and I much prefer a tire with a little sidewall bulge. I like a 12.5" wide tire on a 8 1/2" wide wheel. I think it looks good. I personally run a 19.5" wide tire on a 12" wide wheel.
