Opinions on wheel width
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rockink5, May 4, 2002.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Buying wheels and tires next week. Tires will be 37x12.5 16. Heres the question- should I use an 8" or 10" wheel? I think a 10, but a buddy thinks an 8" wheel is the way to go. Some opinions would be appreciated. Thanks
  2. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    It'd feel more stable on the street with 10"
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I personally would run the 8 inch rims. Check with the tire manufacturer and see what size they recommend. If you do use the 10 inch rims be prepared to do some fender trimming.
  4. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    Interco says basically 8-12" wheel. 12" is way to wide. I will be trimming for fit anyway, so thats no big deal. basically it comes down to preference.
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    With a range of 8" to 12" middle of the road would be 10" but I still think that a 12.50 tire looks better on an 8" rim. Like you said, personal preference on this one.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think 8" would be a bit narrow. I was wondering the same thing and ended up going w/ 15x10 because I will never go to a smaller tire (I have 36x12.5's right now) and any of the larger tires would be wider. Also my tires are actually 13.5" wide so it isn't too bad with width now.
    If you rock crawl? If so you might want the extra protection of 8". If not then go 10".
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd go 10" wide.
  8. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Well a 10" rim will give you a little more flotation and a 8" rim will be protected by the tire sidewall a little more in the rocks. It Depends on what your main use of the truck is. At least that's the "old school" way of looking at it.
  9. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    An 8" rim will hold it on the bead longer than a 10" will too...more contact pressure. That said, I just sold my 8's for a set of tires already on 10's and I'm really hoping they hold up to 10 psi.
  10. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    I love rocks! Thats what I am tring to gear the rig for. Trails and fire roads are also cool. Don't like the mud to much, so I won't be setting up for that.
  11. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I would go with a 10" rim. I've got a set of 33's on 10 wides, and 35's on 8 wides. The look of the 10 inch wide wheel is a lot better. I don't really air down much past 15 anyway, so the bead seating isn't really an issue for me. Floatation will be better with the 10 inch rim too.
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think the hot ticket would be a 9" rim...but that would have to be custom made /forums/images/icons/frown.gif
    The other option is a 8" bead-lock...a bead-lock makes the rim about 1" wider.
  13. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    Any more?
  14. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
  15. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    I've got 33X12.5s on 8 inch rims...looks good and no problems.
  16. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    10
    Later
  17. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I just received new 10" Rock Crawlers via the UPS truck. They are WIDE! My back spacing is 3.75". Any more (to bring in the wheels) would have rubbed the steering.
    Be prepared to stick out a little. Especially on the front. I'm looking for some wide fender flares (see my fender flare post) now.
    If you get 8" Black Rock Crawlers and hate them, I may consider trading. Mine are still in the box. I'm going to get them mounted on some 35's and I'll let you know how it works out.
  18. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,791
    100
    Paducah, KY
    If you're going rock crawling run the 8" rims. As stated earlier it keeps the bead better and protects tires sidewall and the rim./forums/images/icons/smile.gif
  19. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    When I got my 15x10's I was thinking the same thing. They looked WIDE LOL
    But after the tires were mounted on them they looked way better than they did on the 8" wheels.
    And I did notice that the rig was more stable on the road.
    Especialy when on the freeway doing 70mph.
    My wheels do have some rock rash but it's not bad.
    15 psi has worked for me I have not popped a bead yet.
  20. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    If you drive much on the street and a stable feeling is desired then a 10 would offer better control. The thinner the wheel inside of a wider tire the more in and out play, thus the "floating" feeling.
    I said in and out play- hehehe!
