Opinons please! Lincoln Locker ??
Discussion in 'The Garage' started by shane74, Jun 30, 2003.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I do not have the money for a locker, but I need better traction in the front. Since I run a part time kit and warn hubs in the front, is it OK for me to weld the spider gears in my D44? I am thinking the only real draw back to this is that the spiders could shatter on the trail, but they're cheap in comparison to a locker. Any other thoughts on this are appreciated!
  2. GORRILLA
    GORRILLA 1/2 ton status
    May 3, 2003
    315
    TX panhandle, out at the river.
    Get ya an extra set to keep with you on the trail.
    Weld em up, if you don't like it or it grenades, swap in the others
    my .02
    Gorrilla
    /forums/images/graemlins/thumb.gif
  3. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    keeping an extra set of spider and side geras with you is a good idea BUT what are you going to do when it blows and takes the R&P with it or takes your carrier with it My buddy welded his D44 and on the first turn with the hubs locked and 35"s on he blew an axel shaft I don't think it is worth it.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i had a friend who welded his. all u had to do was look at it wrong & it would break. got a lot to do w/ who welds it though. he costantly broke axles & carriers. i don't think i would weld a frt 44.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i wouldnt do it on a DD though..
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Lincoln Lockers suck! Save yourself the hassle and save for a real locker.
  7. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    I welded mine about 2 years ago and broke 2 outers,1 hub,1 inner and finally broke the carrier in two...now ive got a d60 welded and no more problems.........I say weld it and keep spares with you until you can get a d60.....I still made it alot further on my welded d44 than i would have if it was open!!!!!!
  8. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I wouldn't do it again with stock axles. Too many broken stubs and inners. It isn't worth the trouble of constantly changing them trailside.
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The problem with welding the spiders are just that of what was said. When your out wheeling and the spiders are welded, there not going to give like a limited slip would, therefore, when somethihg has to give, it will be other parts such as, u joints, hubs, axles whatever, unlike if you had a limited slip, it gives a little, and its not as hard on everything else.
  10. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    A limited slip would seem like the way to go on a Dana 44, just don't think it is up to the pounding of being locked up. I have a trak-loc which isn't great but it definately helps out on the trail and I haven't broke any parts...yet /forums/images/graemlins/thumb.gif
