opnions on this harbor freight peice of equipment?
Discussion in 'The Tool Shed' started by spongeidys, Mar 19, 2006.
  1. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
  2. KingDuramax
    KingDuramax 1/2 ton status
    Jan 17, 2006
    451
    NY 14701
    It is a pipe bender not a tubing bender which means it will kink tubing. If that is what you are looking to do with it. Like building Roll cages and bumpers and such.
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i've got one of those. i think i got mine on sale for around 100$.
    works decent to bend black pipe, will not bend tube tho. i used mine to make a simple bumper, but main problem with it tho is there is no degree wheel like there is on a tube bender,so getting a bend just right or making to bends match is very difficult. i would suggest saving up or splitting the cost with a buddy and getting a manual tubing bender. they cost around 700 i think for a basic setup with one set of dies.
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    pretty much junk.. I sold mine.. new for 60.00
    if you are doing tube.. you have to spend the money for a good bender ... cheap ones only cost more money in the end...
    Im about to buy one.. with two dies it will be over 2k... electric over hydralic... manual would have been about 600 less
    you can buy one from lo buck tools or jegs for a little cheaper but they are a different style and no degree wheels
    sorry.. theres just no good cheap way... Ive tried them all
    packing tube with sand,,,packing tube with water and manually bending aound something... like a chinaman... mickey rat..
    sticking a spring inside the tube.. still kinks
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Yep. I have one and think that its basically a POS for what I was trying to do. It is fine for pipe, but as mentioned, there is a lot of trial and error to get the bends right.
  6. spongeidys
    Jul 6, 2005
    2,566
    guess we'll look for something better then...i plan on getting building my own cage at some point so i need one for that...manual operation is fine for me
    me and a friend are planning on splitting the cost
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You might want to check out this site if you haven't already. I have personally seen this bender in person and the quality looks to be very good.
    http://jd2.com/
  8. spongeidys
    Jul 6, 2005
    2,566
    anyone have any experience with the model 3?
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Definitely look elsewhere. There are guys who have made do with that bender, but the designs have to be made to allow for the problems and limitations, (such as no bends over about 70*). Plus. even if you use the anti-dent and anti-kink tricks, you will still scrap tube.
    Look into JD2, ProTools, and NE5 bender frames for a better solution that can go to 180*.
  10. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    I have a 12 ton unit of the same make and I built this. You just have to have patience with it and be smarter than the machine. Note the triple bend on the bottom bar out of one piece. But then again I am just a little old carpenter that taught myself to weld, What do I know.
    P.S. Don't try to use it for exhaust pipe!
  11. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    I can see the flattening of the tube in your pic. That is why these PIPE benders are not good for roll cage construction.
