Optima batteries - pro / con?
Discussion in 'The Garage' started by 4by4bygod, Apr 3, 2007.
  1. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    My dad is fixated on buying an optima battery because it supposedly won't ever leak.. he wants to use one in his C5, 'cause there's a bunch of electronics underneath the battery tray.. he's worried about the die hard just randomly leaking one day..
    so he goes to autozone to buy one, and they say optimas are best for trucks 'cause they take a beating, but for a car that sits in winter, they don't hold a charge for very long..
    so - are optimas worth the money for a street car that isn't winter driven?
    should he buy whatever battery is on sale, and buy a "battery saver"?
    should he not worry so darn much?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm pretty sure the opposite is true, Tom. I recall reading somewhere that Optimas hold their charge LONGER than conventional batteries while left sitting..........:dunno:
  3. dick_landy
    dick_landy Registered Member
    Mar 17, 2007
    82
    winnipeg,manitoba,canada
    i heard that if they die, they are difficult to accept a charge
  4. Seafarer76
    Seafarer76 1/2 ton status Premium Member
    Apr 10, 2006
    340
    Las Cruces, NM
    Mine got drained completely a couple months ago. Charged it slowly overnight (as per the instructions) and it worked like a champ after that. Still going strong. From what I have read, most people try to charge them too quickly, which leads to premature failure.
  5. Can Can
    15,552
    136
    FWIW, the V3500 sat for 4 months with the batteries disconnected, in some damn cold temperatures. I hooked the batteries back up, turned the the key, and the truck started up with no problem.
    I'm running dual Red Tops on that truck.
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Buy a trickle charger. One that has an auto shut-off. Winter problem solved;)
  7. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    I run two red tops in my blazer, and after sitting for 8 months, the truck fired up with only a slight hesitation. and they are still going strong
  8. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    my red top will hold 8 volts forever. However that doesnt seem to be enough to start the truck so I trickle charge it the night before I plan on using it. When its driven a couple days each week it works fine. If I let it sit connected for a week straight its right back down to 8 volts. I've left it sitting disconnected for a month now, just checked it on the volt meter... 8 volts.
  9. 454k30
    Sep 13, 2004
    1,613
    California, MD
    oh and mine is a red top.
  10. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    I've got Yellows in everything. Dual in the 'Burb, one in my WIFES tj and one in my '91 S-10 350. Never had a problem with any of them.
  11. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I've got a red top in the K5 that was drained completley several times last year due to the move. I would move it from house to house and then it would sit for several weeks. I forgot about the LED on the alarm which completley killed it. Put a slow charge on there and it would fire up. THis did however kill one of the cells about 3 weeks before the 3 year warranty went out. Replaced it for free.:D
  12. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have a Red Top I let sit for over 5 weeks in New England winter.
    I then went to start the truck and vrooooom started right up:D
  13. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    my red top sat in my crew cab for 8 months disconnected, dropped it in the blazer and she fired right up with no power loss at all.
  14. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I also have a red top and have only needed to jump it once, 5 below zero, setting for 2 monthes and it cranked for a awhile before I relized I was not getting any fuel. Very good batteries over all. J
  15. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    there is no way a LED for an alarm would kill your battery.
    you could leave a LED hooked up to a car battery for a year and the voltage drop would be less than 2 volts. An LED draws between 10 and 40 milliamperes, so it is safe to say something else is causing a draw in your eletrical system.
  16. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    Dangit, why did you have to point that out. Here I thought I had it all fixed up. Now I must go find something else causing the draw.
  17. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    while we are on the optima subject, what is reccomended for a Semi-daily driver/ work truck/ mud runner/ something to run winches front and back with accessory lights?
    Red or Yellow?
  18. Seafarer76
    Apr 10, 2006
    340
    Las Cruces, NM
    If you are running high electrical loads with the possibility of using those loads with the engine off, go with a yellow top. That way you have a starting battery which is capable of deep cycling.
    my $.02
  19. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I am very pleased with mine, one red & one yellow. I just went to buy another and it appears the price has gone up over the past 5 years. Anyone know who's got the best price?
  20. 4by4bygod
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    I saw today that sams club has them for 155.00..
    Anyway, dad is still deciding what he wants to do.. he read through all of the responses, and says thanks for posting up... and I thank you too.. :waytogo:
