Optima batteries
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Aug 12, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    Red or Yellow what is the differnts and witch one is better to run dule batteries in a K5 and how would or sould I go about hooking them up if I got them?
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  3. James90
    May 18, 2000
    986
    Rocky Mount NC
    that thing was cool but I did not see a price for the isolater
    thanks Blazer Guy
    [​IMG]Go prepared
  4. ggallin13
    ggallin13 1/2 ton status
    Mar 31, 2000
    199
    Northern Nevada
    I think yellow is the bomber one. I am running a Wal-Mart battery now, but I am going with Optima'a when I install my dual battery setup. My buddy has one, and he swears by it.
  5. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I just got my yellow top, love it so far
    Your right I dont understand the jeep thing!?
  6. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Call the Optima Company before you use an isolator-it might void the warrenty. I used one 5 years ago and fried one of my optimas-that's how I found out about the problem. Optimas have to be charged between 13.7 and 14.2 volts, if you go over that for any length of time-optima fried. An isolator will cause this to happen. I was told to hook the Bats. up in parallel or get a dual output alt. New isolators may be improved but I wish I'd been informed-it might have saved me $130
  7. jim82
    jim82 Registered Member
    Jun 27, 2000
    71
    Bay Area
    deep cycle is made to be run down all the way and then recharged. if youre gonna run it off a alternator all you need is a red top cause its gonna be charged constantly. yellow ones are good for things like trolling motors, golf carts, hydros etc.. cause they can get used up all they way with no damage. normal(reds) would be damaged if you discharge them totally a bunch of times. just my .02
  8. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    The prices are on Hellroarings web site:
    http://www.hellroaring.com
    A company might change it's prices at any time without notifying off-road.com so the prices are usually left out. To save a trip here they are:
    BIC-75300A $149.95
    Remote Module (optional) $39.95
    (you can make this yourself to save money)
    The Hellroaring is one of the best isolators and should be ok to run dual Optimas with it.
    Shawn
    87 K5
    few mods
  9. James90
    May 18, 2000
    986
    Rocky Mount NC
    that is not bad at all. Do any of yuo guys run dule batteriers with that setup or a deffernt one is it worth the money is it hard to setup and how many amp alt would I need to power that setup?
    sorry about all the ?s its just that I thank I might want to do this.
    thanks guys
    [​IMG]Go prepared
  10. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    Just a side note: I saw an ad for Champion for a battery that uses Optima's spiral-cell tech. I don't know the specs, but it might be worth a look to see if they are cheaper than the Optimas.
    Eric78K5
    K5-Because Size Matters!
  11. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have a dual set of Red Top Optimas and am using the Hellroaring iso/combiner mentioned above! I wouls have to say it is the BEST on the market!! THe BEST! IT is small and smart! IT will not let the batteries go above a certain vontage nor will it allow them to go bellow a certain voltage(as log as the alt. is working of corse)!! I recomend using the modual too just cuz it gives you incab diags on you electical system! YOu can tell when your alt is not putting out! You can tell when your 'main' batt is not holding a charge and you can combine both batts for Xtra power when needed!! VERY sweet set up!
    Red top is all you need for a K5.
    Oh and the customer service for Hellroaring is TOP NOTCH!
    They even replaced my iso FREE of charge when I letterally SMOKED it by not dissconnecting ALL the grounds from the batt!!
    GO FOR IT! Save your bucks and you WILL be happy!!!!
    sorry got excited and have allot of coffee in me[​IMG]
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  12. Shawn
    1,753
    5
    5280'
    James-
    You could stay with your stock alternator for now. I'm running a stock alt with the dual setup and works fine. Even with the 12k Warn winch, the two batteries alone keep up ok. Eventually, I'll have a high output alt. Just haven't had the cash!
    Shawn
    87 K5
    few mods
  13. Burt4x4
    6,854
    I forgot to add that I run a 120amp alt. I got this for 100 bucks. I whent to a local 'autoelectric' shop that did rebuilds on anything and everything to do with automotive elctrics. I waited while they made it and told them it's for a trail rig so they used heavy duty bearings,fan wheel and pully. THe power of the yellow pages!! [​IMG]
    ok no more coffee for me my back teeth are floating.......
