Optima battery Failure (rant) anyone else?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Jun 10, 2002.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Ok I am a little tweaked right now.... got in my trail rig, she started hard 'cause she hasent been run in a few weeks. Drive to Walmart batterys dead wont start. Get a jump get home, check the voltage about 12.5v at idle. Figure its a bum alt. jump it the next day to drive it to my shop. Amp gauge is pinned out at 60a+ (charging) Pulled the cables off alt is putting out 14.5. Battery is toast.
    This battery is a year old redtop, on a recreational seasonal vehicle. Optimas site dosent even tell what kind of warranty they have they say "consult your vendor for warranty info" Glad I bought it through summit. Between the shipping and I'm sure a prorated adjustment it probably wont even be worth replacing. I plunked down a extra $50 for this super battery and what the hell did I get out of it. Sorry for the rant but....
    Does anyone else have optima problems?
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Yep, had a bad one myself already also...and my brother has had two replaced by 4WParts already...I keep hearing bad things about them (but when does anyone say much except when there is bad news?) When they work, they are great, but seems to be some of us who get bad ones too often...
  3. Grim-Reaper
    7,385
    Atlanta
    Don't like them. I think they are WAY over rated. I have seen several fail. Simular deal. Just for no reason dead and would not charge. Seen the side terminals burn off whit winches hooked to them. some have a 12 month warranty some have a 24.
    I hit my local zone and got a 1000cca Duralast. 3 year replacement 8 year total warranty no questions asked. $40 cheaper than the Optima. My truck is some times parked 2 weeks at a time and never gave me a lick of trouble. Starting it after 3 years.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i had my redtop for about a year and it went bad i took it back they have a 1 year store warenty so they exchanged it for me i upgraded and got a yellow top because of the winch and its been great ever since /forums/images/icons/smile.gif
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I don't like the Optima's ether.. I've worked for Sear's,and bought a couple of gold batteries from them. They alway's give me the "better" deal. If they die, I have a warranty,and don't pay a thing. /forums/images/icons/grin.gif
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    The Optima documentation says not to hook a winch to the side posts. Only the top posts...
    I really had my heart set on an Optima, but now I am reconsidering.
    Anyone recommend the batteries sold at Sams Wholesale?
  7. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i have had good luck with the excide sprial battery...its been in the truck for almost a year and never have had a prob...not even a week start
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've had my red top for about a year and a half now with no problems. *Knocks on wood* /forums/images/icons/crazy.gif
  9. kpanza
    Dec 8, 2000
    1,579
    Hmmm, I don't recall ever seeing this info about not hooking up the winch to the side posts? Where did you get this information?
    I have had mine hooked up to the side posts for about 2 years with no problems (so far)...have used the winch numerous times, did
    I just get lucky??
  10. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Here is the link. It is under the "Battery Installation Tips" section. "Connect high amperage accessories such as a winch to the top terminals only. Do NOT use the side terminals."
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thats what I bought
  12. dyeager535
    26,977
    If I read that right, you pulled off the battery cables while it was running? IIRC that can or will burn up the alternator diodes(? trio?) and while it will still work, diminishes the alternators capability. FWIW, I've heard that multiple times.
    Besides, you can measure output voltage right from the terminal on the back of the alternator.
  13. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Off-topic but what in the hell does 'IIRC' and 'FWIW' stand for??? /forums/images/icons/crazy.gif
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    not sure about the iirc but the fwiw is
    for
    what
    its
    worth
  15. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    For what it's worth but I'm stumped on the other.... /forums/images/icons/crazy.gif
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    If
    I
    Recall
    Correctly
  17. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I have a less schwab 4x4 battery and It gets some hard voltage drains with my winch I have draind it 7 times and it still tickin and plus it has the famous less schwab warrenty on it to.
    Colin
  18. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    aaaaahhhhhhhhh thanks /forums/images/icons/smile.gif /forums/images/icons/grin.gif /forums/images/icons/cool.gif
  19. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I like my Exide Orbital (spiral cell). It has been deep cycled a few times (I am a moron!) and is still kicking 2.5 years later. I can run my stereo all day and my lights up front for a while too.
  20. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    That clears things up..... /forums/images/icons/smirk.gif
