Optima or Exide Orbital?
Discussion in 'The Garage' started by Desert Rat, Dec 18, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Ok, went and did a search and read a lot of differing opinions on batteries. But, I have narrowed it down to two Optima red tops, one Optima red top and one Optima yellow top, or two Exide Orbital batteries for my two new batteries I need. I'm running a CB, stereo, and 9.5ti winch and maybe some extra lights, on top of the usual stuff. Opinions? Oh, and that last choice should say "battery" not "better". Damn thing won't let me edit the poll questions.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    why not just 2 yellows? Whenever I get $$ for 2 batts and all teh extra crap to put on 2 batts, thats what im going to go with.
  3. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    I use(d) a red top....no probs, tossed it around, beat on it, and ne'er a problem. But I'm naked....
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I have a red and a yellow, the kick a$$....When I first took the poll it took me to the results and under that was a post started by Steve about some embroidered baseball caps, anybody else get that quirk....:confused: :confused:
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Yeah, me too. WTF?
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    AGM batteries suck. Just get normal plate/acid batteries and do yourself a favor.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I vote 2 reds. (poll doesn't like me :( )
    Mine are 800cca and cost the same as the 750cca Exide.
    The red is meant for starting/cranking and is designed to take constant charging.
    The yellow-top is deep cycle. It's meant to be run right down before its re-charged. If you mix battery types, you should have the deep cycle isolated ( solenoid, isolator, switch, etc). Consider how often and long you are using battery power without the vehicle running.
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
    I do have mine ran on an isolator and can run the **** outta the tunes and still fire the truck up with the red....:saweet:
  9. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    A recent four wheeler magazine had a comparison of a bunch of sealed batteries. I think in the end the only difference was the cold cranking amps.
  10. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have run the same excide orbital in my s10 for around 5 years. It is just getting to the point of needing to be replaced. I have deep cycled it more times then I should have (I play the radio when I work on it of the K5 and other stupid things). If you search on the net you can pick them up for a much better price then red/yellow tops. If I didn't get the last 2 batters for the k5 for free I would be using an excide orbital in it as well.
  12. blazen86
    blazen86 Registered Member
    Sep 8, 2004
    55
    Virginia
    How about somebody make a kit for the older chevys so we can all bolt on two batteries, I mean with all the lights, amps, and winches we need some more juice
  13. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Went with the two red top Optimas. I heard that Costco had them but I didn't want to make a trip unless they were the right ones. I called down there three times and spoke to a complete incompetent every time. I kept asking what the model number was and they kept coming back with "It is a type 13". "No, is it a 75/35? or is it some other model?". Same answer no matter who they sent back there. I gave up. So, down to Monument Auto Parts to check on their prices. Low and behold they are $119 a piece. The Exide Orbital over at Kragen Auto Supply was $130 a piece so I think I'm ahead of the game.
    Keep in mind that 4WP has them advertised for $90 a piece, but I didn't feel like dealing with waiting, or driving to San Jose to get them. I pick them up and I'm happier than a pup with two peters. Then the missus and I hit Costco the next day. $%&*!!!! :mad: #$%^&* :angry1: They have the 75/35 in stock for $99 a piece. Well, I took the other two back since I hadn't opened them yet and picked up a couple from Costco after all. They carried the blue tops too, but not the yellow tops.
  14. dcell152
    dcell152 Registered Member
    Sep 23, 2004
    84
    Nothern Maine
    dual batt.
    the 6.2 diesel came with dual batt. You should be able to order the harness. My 84 had that set up.
  15. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    You mean like GM? :D
    You can get all the parts you need from your dealer or LMC. There's a different set for 73-80 and for 81-91, but there was a factory option for a second battery on all trucks.
    -- A
  16. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    You can get the other battery tray from LMC ('bout $50 IIRC). Do yourself a favor, though, and make your own battery cables out of welding cable. I've got an '87 C10 with a 6.2 in my driveway as a parts donor, and GM's dual-batt wiring is a disgrace. I've seen people use heavier-gauge wiring to run a decent-sized stereo amp...
