Optima Question
Discussion in 'The Garage' started by cbbr, Aug 6, 2005.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Obviously, I have a dead battery.
    Last week it was "what kind of battery" the majority, by far, seem to run optima's or that style of battery. Red top, yellow top, blue top and the many variations of each - What are you running and why?
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I run red tops in the truck... they are automotive type
    blue tops (deep cycle) in the rv...
    never used the yellows
    red 100
    blue 140
    costco... free 36 month no hassle new battery replacement
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I have dual red tops.
    The red is a cranking battery. It's meant to deliver huge amps for short periods.
    A deep cycle is meant to be run at light/moderate load for long periods, and then recharged.
    Don't mix'n'match them unless you have an isolator or some other battery management system in place.
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I run a yellow top, its expensive, but ive had the truck off, and kc lights blarin' for 30 minutes or so, got in, and it was like i just turned it off. If you are just looking for a reliable battery, then go red top, if you run a lot of electrical accessories, then go yellow, deep cylce batteries make a big difference.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I run a dual red setup in my DD, I've killed the whole system once (don't ask) and they recharged fine. I've also blared my stereo for 4-5 hours at a bonfire and it cranked like nothing ever happened. We run a blue top in our boat and it'll run all weekend without problems. When I get around to it I'll probably run dual yellows in the trail truck. I like a lot of things about Optima's, they're completely sealed (although that's not all that unique anymore), they've outlasted most of the batteries I've used, and they're just plain tough as hell. Marine applications are more of a testament to durability than people realize. Pounding a hull against a good chop all weekend is as bad or worse that 'froading in terms of shock to components.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run a yellow top because i have a winch lights and stereo system it has never let me down
  7. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I have dual red tops. I got them from Costco believe it or not and they were under $100 for each.
  8. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I have a red for starting power, eventually with lights and a winch I will add a yellow.
    Jesse
  9. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I have a redtop in one truck and an exide orbital in another. Both good batteries.
  10. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I was originally going to run dual yellow tops, but I think im gonna run dual red tops. I don't think the deep cycle batteries are meant for quick bursts of power, like starting the car and winching. I have read that from several places. Heres one:
    (From 4wp website)
    Red:
    http://www.4wheelparts.com/4wp/prod...PER&prodline=125&catName=Performance&man=OPTI
    Yellow:
    http://www.4wheelparts.com/4wp/prod...PER&prodline=126&catName=Performance&man=OPTI
    I have heard a lot of good things about them, and no one I know who uses them has ever said a bad word, except a little on the expensive side for batteries. But hey, were in the wrong hobby for a cheap way out. :D
    -Randy
  11. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    I don't know about all these colored tops and such. I just run a champion Trailblaser 820CCA
    i've got nothing but good things to say about it.
