OPTIMA sidepost hook-ups for a WINCH?
Discussion in 'The Garage' started by MTPockets, Sep 16, 2002.
  1. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    would like to find out your experiences with this subject. is this a big NO NO or what...
    thanks in advance!
  2. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Big Huge No No. I currenlty have 2 red tops. Had a Ramsey 9500 hooked up to the side mounts, and melted the lead completely off the battery, had a tough time getting Optima to warrantee out the battery.
    For everything else they are fine, but not for the winches in my opinion.
    Just my .02 worth. /forums/images/icons/smile.gif
    Rob
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    everything i have heard is that hooking up anything but yer starter to the side post is a NO NO.
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Glad I read this one!
  5. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I'm not sure I understand the reply's on this. Are you guys saying not to use an optima for the wench? Why would the side posts hookups be any different than the top ones? I was planning on using a yellow top for my 9500. It would be great if somebody could shed a little more light on this.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have two red tops and ALL of my truck's power comes from one battery. I am using the sideposts for the entire trucks power but my winch is hooked up to the top posts on hte 'main' battery. Duno why the side post would be a no no unless it has something to do with the type of batt connector being used. I am using the clamp style side post connector that you simply bolt/clamp to the batt cable of your choice(Not the premade ones) could that be why I have had absolutly no issues?? Colud be the pre-made siidepost ones that don't hold up to all that amprage?
    HHmmmmmmm??????
  7. Grim-Reaper
    7,385
    Atlanta
    Back When Rob was here in Atlanta we have seen SEVERAL Optimas melt the side post out. The top posts are right to the plates. The Side post comes off the top and then down to the side. It has a standard nut that is captive in the lead. Well it doesn't make the best connection cause those fools that make that battery are using a zink plated nut. It starts create resistance and heats. Then it melts the lead and pulls out. If they had used a harder lead and tapped it like most side posts are it wouldn't be an issue. If they had used a copper nut it porbably would have been fine but when you use a Zink plated $1 for a 100 nuts and put a couple hundred amps to it you get problems.
  8. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    I think the side posts dont have enough contact to the connector to support the amperage a winch pulls. The top mounts have plenty of contact therefore less resistance.
  9. Burt4x4
    6,854
    Nut?? What Nut? Do you mean the bolt that screws the sidepost to the battery?? If so my batts didn't come with anythig. I am using the copper side post post that enables you to hook terminals too, are thoes ok?
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    is this for any battery that has top posts and side mounts?
  11. Grim-Reaper
    7,385
    Atlanta
    The nut is IN the side posts of the battery. It's the threads that you put the bolt into. I know what they have because after it cooled down when My bud melted his off we got to looking at it. Rob was there for that....We were DRAGGING KYLE FROM KMA out of a mud hole he sunk his truck in LOL. It ultimatly totaled the truck.
  12. Grim-Reaper
    7,385
    Atlanta
    Might have an issue with that. If the Lead had a nice big contact area for the copper side post you put in it then you might be ok but after what I have seen I sure wouldn't hook a winch to the side of one. Accessories like lights and stuff... yeah proably ok. Might even get away with the started because you don't lay into it but for a very short period of time. Winch that gets stalled is drawing over 400 amps.
    Right from Warns Web page for a HS9500i.
    12V DC PERFORMANCE SPECS:
    Line Pull
    Lbs.(Kgs.)
    4000(1810)
    6000(2720)
    8000(3630)
    9500(4310) Line Speed
    Ft./min.(M/min.)
    62(18.9)
    16.3(4.97)
    11.8(3.60)
    9.31(2.84)
    7.59(2.31)
    6.67(2.03)
    Motor
    Current
    47 amps
    160 amps
    230 amps
    305 amps
    370 amps
    425 amps
    Pull by layer:
    layer/Lbs(Kgs.)
    1/9500(4313)
    2/8650(3927)
    3/7920(3595)
    4/7400(3359)
    5/6940(3150)
    Ehhh that didn't transfer well. At 6k it's pulling 305 amps at 9500lb on bottom wrap it's pulling 425 amps!
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    everything Grim said is correct. Here is some info from Optima's web site:
    "Battery installation tips
    Ensure that the battery is properly secured in the vehicle or equipment to prevent movement or vibration wear. Do not over tighten the hold down bracket, this can damage the plastic case.
    Connect high amperage accessories such as a winch to the top terminals only. Do NOT use the side terminals.
    Replace any cables and connectors that have corrosion, rust, or other damage.
    Do not install batteries in a non-ventilated or sealed compartment.
    Do not lift or handle the batteries by the terminals.
    Do not over tighten terminal bolts, the following values are recommended:SAE automotive terminal:50-70 inch-lb.Side terminal (3/8" nut):70 inch-lb.Threaded stud terminal:120-180 inch-lb."
    Do not hook a winch to the side posts, only the top. They even tell you not to.
  14. Burt4x4
    6,854
    AHhh my bad Grimm, I just reread you post and the nut INside the lead! Got it!! Sorry man!
    Good Info fellas! Even though I haven't had any issues I may plan to get my acc off the sidepost and/or move the Alt wire &amp; starter to the top!!
    Great Info!
    Late
