optima... which one?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chevy409, Jun 10, 2001.
  1. Chevy409
    Chevy409 Registered Member
    Mar 5, 2001
    81
    There's a yellow top and red top in the optima batteries... what's the difference besides price? Is either one better? Need to buy a new battery soon so any advice or info is appreciated. Thanks
  2. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    The Red Top Optima is a starting battery. It's designed for quick bursts of energy for a short time duration. Completely discharging the Red Top can cause permanent damage to it. The Yellow Top Optima is a deep cycle battery. It is designed for a steady power drain over a long period of time and can be almost completely discharged, without causing damage to the battery. To help you determine which battery is best for your use, we need to know how you intend to use it. Do you have a high power draining stereo, a winch, or high wattage off-road lights, etc? It would also be helpful if you filled out the rest or your profile.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've had my red top in for about 8 months now with no problems. I just use it to start the truck and not for a winch, stereo, lights etc.
    Murphy's Laws on Life :
    "The longer you wait in line, the greater the liklihood that you are standing in the wrong line." [​IMG]
  4. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Personally, I use the yellow top in my truck. Never had a single problem with it. dont have a winch on the truck and rarely use the off-road lights. Yellow top works just fine as a starting battery for everyday use. Both the red top and the yellow top are good batteries. Descide what you want to spend and go buy one.
    78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt w/ Detroit
    <A target="_blank" HREF=http://www.bowtiecrawler.com>http://www.bowtiecrawler.com</A>
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the red top one in mine and i do use a winch and off road lights and have hade no problems with mine
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Like I always say....get the interstate. They make optima, it's the same battery, with a better warranty and easier to find dealers locally to cash in on that warranty. Look into it.
    <font color=red>Sherman, Tx
    "I'd Rather Be a Fencepost in Texas than the King of Tennessee" -Chris Hall
    TEXAS COUNTRY PRIDE
    </font color=red>
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    What are the CCA ratings for the Optimas...?
    I will go try to find a website.
    Dave
    "Visualize Whirled Peas"
  8. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    Got a red one on mine and I run my stereo a lot with no probs. I'm sure both are top notch.
  9. Chevy409
    Mar 5, 2001
    81
    Thanks everyone
    Gandolf: Yes, I'm putting a winch in and have a few extra lights. I also want a battery with atleast 800 cold cranking amps though so by the sounds of it, I need one yellow AND a red (d@mn).
    laketex: Are the interstate batteries the same as optima in construction (gel inside, can mount anyway, etc.)? What are one of these things gonna cost me?
    Thanks again everyone. 96C4and91K5 read my mind though, what are the optimas rated for cold craking amps?
  10. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    800 CCA, but I have seen the red top do about 1000 Amps. at 80 degs F.
    The red tops seam to like to start Deisels.
  11. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Specs are linked under the pictures:
    <A target="_blank" HREF=http://www.optimabatteries.com/main.htm>http://www.optimabatteries.com/main.htm</A>
    Dave
  12. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    And they have 36 month FREE REPLACEMENT guarantee and a 72 month prorated warantee. 800 cold cranking and 1000 cranking. No probs with my red top. Optima says the yellow ones are also good if you vehicle sits for long periods of time in between driving it. I have the yellow top in my El Camino and it has sat for 6 months and started right up.
  13. Josh
    Josh Registered Member
    Dec 11, 2000
    75
    Glendale, AZ
    If a yellow top will start your truck then I would get that, the higher cranking of the red will only help in very inclement weather. The yellow is much more durable. I have several, one was on my Caprice w/ 1k watt stereo and has since been in 3 other cars, with several discharges over the last 5 years or so, it just keep chuggin.
  14. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I am installing dual batteries (the switch, cables, and controller from NW power should arrive today :)). I currently have a high-output AC Delco as my primary.
    I will have a winch in 6 months also.
    So - would everyone agree that I need to get a Yellow top as the auxillary?
    Dave
  15. Josh
    Dec 11, 2000
    75
    Glendale, AZ
    I wouldn't mix and match different ratings of batteries with each other. They will load on each other and try to "level out" and you will have some wierd stuff happen. If I'm not mistaken usually you would use an isolator when running multiple batteries, however I read somewhere that someone from optima said not to use an isolator with their batteries. I know that vague but maybe they have some tech help that can calrify that.
    Josh
  16. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Thanks! I will now investigate that.
    The controller I am getting has three settings - one for connecting the batteries and the others for switching primaries I think. So I better check it out.
    I'll post the findings.
    Dave
  17. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I'm currently (no pun intended) running dual red tops with a Hellroaring Isolator/Combiner. This is one AWSOME setup. I'm completely happy with it. I did a lot of research on this before I decided and have no regrets. I'd go with the yellow top if I were you. Plenty of CCA for starting and lots of capacity. If my primary starting bat (red top) EVER dies I'll replace it with a yellow and keep the other red top as my starting backup battery.
    Hope that helps...
    James
    79jimmy@home.com
  18. Chevy409
    Mar 5, 2001
    81
    thanks again everyone, I think yellow's got my name on it since I plan on winching. I'll let you know how it goes...
  19. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Unless Interstate's come out with a new style battery, it's nowhere near to being the same thing as an Optima. (just try to mount you interstate upside down) Don't get me wrong, interstate makes good stuff, but Optima's a totally different animal. read:spiral wound gel-cell.
    Why do people keep calling it a Bronco!!!!! [​IMG]
