Optimas
Discussion in 'The Garage' started by cegusman, Jun 7, 2006.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Going to order 2 optima batteries soon. They ar going in my k5 with the 6.2 and 2 winches. What color do I need to get?
  2. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    Eventually I'll have dual Optimas too. I will probably be going with the red tops (I've already got one and havent had a single problem with it). I've heard of quite a few people having problems with the yellow tops being used as a starter battery.
  3. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    I have dual yellow tops. Only been in the truck about a year and a half. No problems at all. Plenty of power for anything. Rob 85K5 has been running a yellow top for at least a few years no problems either.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I've been running dual yellow tops for a year now. Also using the Hellroaring isolator and a Powermaster 250 amp alternator. I have had no issues at all. The previous batteries like to leak when I got on a steep incline.
    One thing I have noticed was the yellow tops seem to hold a surface charge longer when I shut the motor off. I have an LED light on the dash showing the charge. The old batteries (which were new 1000 amp batteries from Wally World (Walmart)) would loose the surface charge in a matter of seconds. The light stays on now for a minute or two.
  5. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    I'm running dual yellow tops myself, no problems either
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    OK, I guess I will order 2 yellow tops. Now whats the cheapest everyone has found them for?
  7. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I have a red for starting and yellow for winch and accessory stuff. Reason is the red is better for starting, the yellow holds charge for a long time so is suited to use as aux battery. Also using an isolator and high amp alternator.
    I think they run about $110 each. You can get them at autozone - just make sure they are fresh.
  8. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    sams club has them cheap in their auto dept cheapest i have found yet
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    at advance auto i think they are $109 for red and $169 for yellow
  10. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Costco has them also.... May want to check their if you have a membership....
  11. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I have a red and yellow too, you can run your cd changer all weekend before you need a jump...All weekend...:haha: :wink1:
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    but what if you've got like dvd monitor and subs a stuff?;) :haha:
  13. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I have one of the BIG yellow tops. I dont remember the exact group number but it has 900 cranking amps and the cells on it are staggered instead of lined up normaly. I had to special order it from Jegs and it was on backorder for 3 months till I got it.
  14. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    I bought one of the first series of red tops to come out almost ten years ago, It's an 800cca battery, I recently tested it @723cca. I think this battery is going to last forever! truly amazing!
  15. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I would do two yellowtops on a truck ment for mostly offroad. 2 reds wouldn't be terrible either though. 1 redtop had gotten my K5 by for years now with no problems. The only time it won't keep up is LONG pulls with my Warn 12K. I only have an 80 amp alternator though which doesn't help its case any.
    Harley
  16. Tabb
    May 2, 2006
    3,566
    21
    Heart of Dixie
    My red red top had been going solo up until 2 years ago when I got a dual batt. isolator. It did o.k. with light, short winching, but now it has a 600cca A/C Delco to help it out. In my personal opinion, If you are running dual batteries, I would not spend the extra money for a deep cycle aux batt. regular batteries will work fine.
  17. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I used to run "normal" batteries, however every time I would go off-road they would puke acid all over the place. So finally I spent the money and bought a Optima red for starting and a yellow top as my accessory battery. I've had the batteries since 2001 and there still going strong.
