optimum backspacing on 14FF *DELETED*
Discussion in 'The Garage' started by eripley, Mar 10, 2004.
  1. eripley
    eripley 1/2 ton status
    Oct 1, 2003
    145
    knoxville,tennessee
    Post deleted by eripley
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: optimum backspacing on 14FF
    With 5.5" backspacing on 8.5" ( /forums/images/graemlins/crazy.gif) wide rims, you'll be tucking the tires pretty far into the fenders.
    I have 2.75" on 8" wide rims and it looks really good...the tires line up pretty well with the body.
    As far as "will it work"...most likely. What diameter rims are we talking? 15's? 16's? 16.5's? 24's?
    The 15's might cut it close but will probably still work. Any diameter larger than 15 will fit no problem.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    If these are 15" rims you'll have a heck of a time clearing the front rotors. Think grind all day and night. If they are 16" or larger should clear fine.
  4. heavy4x4
    Aug 28, 2002
    3,270
    True. I wasn't thinking about the front axle. You WON'T fit a 5.5" backspaced 15" rim on a 3/4 ton front axle. Not only will the grinding on the calipers and backing plates be ridiculous, but you'll probably have interference problems with the rim and tie-rod.
  5. eripley
    Oct 1, 2003
    145
    knoxville,tennessee
    Im sorry these are 17" rims. And I want to run 35x12.50 or 315/70 on them. I should have been more specific.
  6. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    H2 rims, by chance? /forums/images/graemlins/thinking.gif Time for wheel spacers.
  7. eripley
    Oct 1, 2003
    145
    knoxville,tennessee
    /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
    okay thanks!
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Did GM change the backspacings of their newer trucks? It seems that since the avalance, they have move the backspacing to the outside edge more and more. Did they actually change the spindle offset out more? It would seem that any h2 rim/tire would fit just dandy on any 88+ IFS rig.
