Optimum pressure for BFG AT KO's...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burbinator, Nov 23, 2001.
  1. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Optimum pressure for BFG AT KO\'s...
    I'm sure this has been asked 1000 times...here goes 1001.
    Looking for the optimum pressure for my BFG's for the STREET. I am getting conflicting numbers from various persons that don't wash with my own "magic" number.
    Interested in your opinions...TIA
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>U.S.S. Nimitz II</a>
  2. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Re: Optimum pressure on BFG AT KO\'s...
    35psi
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: Optimum pressure for BFG AT KO\'s...
    Minimum pressure should be 80% of the rated pressure which is 28 psi. I run about 32 on mine for the street, but always run 35 highway.
    Bubba Ray Boudreaux,
    "If I had wanted a plastic ride, I'd married Pamela Anderson."<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  4. Grim-Reaper
    7,385
    Atlanta
    Depends on the size. Some tire sizes are rated 50PSI. The 31's and 32's that I have are rated 50 psi. problem is the factory rally rim is rated 40 psi. I have been running 36 front and 34 rear on the K5's and getting good even wear. With the extra weight of a Burb I would say run 36 F/R or 38 F/R if that's the size you have.
    If you have the tires rated 35psi max then I would say about 32.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  5. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    my 33" ko's tend to like about 25-28max for a good ride.. they wear perfectly and dont squat, etc. any more and its bouncy bouncy.. if you have uber-soft suspension, 32 will work for you
    mike
  6. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I run 50 in my 31 10.5 15's on stock ralley rims. Mine are wearing perfectly, no cupping on the front or rear and just a hint of feathering on the fronts after 10K miles. I love my BFG AT KO's
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  7. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    That's what I thought, around 35 psi. I usually run the rears at 42 when towing my boat or tent trailer, when I think about it. I haven't had any problems. 42 psi seems to roughen the ride a little when all four are at that pressure.
    My tires are 31 X 10.5 X 16.5. I've had some buddies who have suggested 45-50 psi for optimum pressure. Apparently, they have never taken a ride in the truck afterward!
    Thanks everyone for your input...
  8. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Grim is exactly right. The others are not helping you to answer your question without knowing the size of your tires as well as the gross weight of your vehicle(that includes all cargo you are carrying/towing).
    Generally, the bigger the tire, the less pressure is needed for the same weight.
  9. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Been running my 33x12.5x15 AT/KO's at 42psi w/o a complaint. They're wearing even and the ride is smooth. The psi will be dropped to 32 for the winter driving ordeal however.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  10. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I run my 33X12.50X15 BFG MT KOs at 35 Lbs. When on roaad and down to 15 lbs. or less for play. No problems.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  11. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    See my previous for tire size, 6000 lbs approx. average weight (normal use duty) of truck. Figure on 2000lbs for my tent trailer (a vintage 1970 Starcraft) and 3500 lbs for my boat.
    I'm more focused on everyday usage vs. towing with regards to inflation pressure.
