Optional axle ratio
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5_73, Sep 30, 2001.
  1. K5_73
    K5_73 Registered Member
    Feb 5, 2001
    53
    Wichita, Kansas
    My Options list that's on my driver's fender well says "optional axle ratio" and the number before it says "1ZN8". Without counting the teeth, who knows where I can find out what that code means? Thx in advance.
    Stupid hurts
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Sorry, don't have that option listed, but here are the options: 3.07, 3.73, 4.11
    That really narrows it down eh?
    Standard with the 6 was 4.11, with the 8 it was 3.73.
    What engine did it come with?
    Still Poundin' "pavment" after 283 Posts!!!
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    2.73's also I believe
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  4. RedDwarf
    May 9, 2001
    816
    Not in '73
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    oh you could be right... I had 3.08's in my 89, and I know I've seen people complain here about 2.73's...
    as far as what came in what years I got no idea...
  6. K5_73
    Feb 5, 2001
    53
    Wichita, Kansas
    It came w/ a 350/4bbl, sm465 tranny.
    Stupid hurts
  7. Grim-Reaper
    7,385
    Atlanta
    with the 465 you probably got the 3.73. 3.08 is the standard gear in most years so it having the option gear it is probably 3.73. 4.10 is not unheard of also.
    On the front diff on one of the cover bolts may be a tag from Dana (even on 10 bolts because Dana built them too) and it will list the gear if it's still there.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Do you have any verifable soruces to quote that Dana built the 10 bolt ?
    If you do please share.
  9. Grim-Reaper
    7,385
    Atlanta
    Yeah the DANA &lt;&gt; Diamond cast into the side of the pig and the fact that all the parts from the knuckles out are interchangable between the D44 on them and every seal including the inner axle seals are DANA parts. If you order a 10bolt axle shaft from GM it comes in a DANA box. Need anymore proof?
    75 Jimmy, Dollar
    Grim-Reaper
