options for the front axles
Discussion in 'The Garage' started by 69K5, Nov 22, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Well I found a 14 bolt 8 lug rear axel out of a 78 for $150.00 today. /forums/images/graemlins/cool.gifdont know what gears but i can swap them if nothing else. What are my options for the front axel besides building up the D44? /forums/images/graemlins/confused.gif$1000 and up for a front dana 60 is absoloutley out of the question. What do i do to change the d44 to 8 lub? unevenness will drive me crazy! also do i have to move spring and shock mounts on that 14?
    well i found a 14 bolt 6 lug for $35 besides price is one better than the other?
    thanks again for all the help /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
    Nathan
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    You should be able to find all the info you need if you do a search.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ok i did a search and found out that i might have to swap my shock mounts if it was a 2wd. some said that i needed to change the perches around. whats the difference? What is the difference between a 14ff and a 14sf besides 6 and 8 lug?
    thanks
    nathan
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ttt
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thev SF has a C-clip just like the 12 bolters where the FF does not. I personally think the FF is stronger.
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i dont do rock crawling just mud and street. do you think the sf will work fine?
    thanks
    nathan
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's not even a matter of thinking that it's stronger, they are definately way stronger.
    the only thing that a SF and FF 14 bolts have in common is the 14 bolts holding on the diff cover, which is where they get thier name. The SF has a smaller ring gear and smaller diamter axleshafts, as well as being a semifloater. The difference between a semifloater and a fullfloater is in the way that the axle supports the weight of the truck.
    On a SF, the axleshaft supports the weight of the truck via a bearing in the end of the axletube that the axleshaft rides on. The wheel bolts directly to the shaft, so the entire weight of the truck rests on the shaft.
    In a FF, the axleshaft's only job is to turn the wheel. The weight of the truck is supported in the same way that it is supported on a front axle. There is a spindle, and a hub goes onto the spindle supported by two large bearings.the axleshaft slides throught he middle of the spindle and is held in place by bolts in the flange of the shaft that bolt into the hub. that is the reason that a FF is so much stronger. </font color>
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It's a good upgrade over stock, but not as good as the FF in my opinion.
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    as SF can't be as strong as a FF in ANYONE'S opinion.
  10. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    maybe i can find a ff cheap enough.
    are ther any distinguishing factors besides lugs? is 8 lug guarenteed to be a ff?
    is ther ff kit like for 12 bolts/
    thanks
    nathan
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    a 14BFF will look like this:
    also, here is a link to a page with what the covers will look like. you want the 10.5" Ring Gear 14 bolt
    Pics of Diff Covers
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    cool thanks
    nathan
