Orbit eye springs
Discussion in 'The Garage' started by the beast, Nov 23, 2006.
  1. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Who runs them?
    How do you like them?
    Who did you get them from?
  2. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Yeah what he said ^^^^
    I'm thinking of getting some Orbit Eyes, as opposed to revolvers for my ORD shackle flip and stock 56" springs. I want to know how they handle on the road....and off road before buying.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
  4. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    Im going to run them when my rig is done. first I did the 63 in. spring conv. and am running tough country 4 in. springs up front. once all the cage work is complete and fuel cell and all the weight is there to see if the ride height is good and level, then I will get the Alcans with the orbit eye for some crazy flex.
    dont care how they work on road as long as there not unsafe. just want major capibility off road. once I get those springs and the truck setup I will move my 63's and 4 in TC's to my burb. have read nothing but good about orbit eyes.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you could run them up front as well right? i guess you have to buy their springs to get them, or can you use ur own springs?
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Can run the up front, and have to use their springs. also you can buy just the joint and install them in your hangers as well
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    My friend has them in both front and rear of his yota. As far as streetability, whoever said they were not is crazy. It feels no different than a typical spring at freeway speeds (or however fast those little hampsters could take us.) The only drawback to the Orbits is that they need routine maintenence. They do get dirty and start to make noise. You need to take them apart and, clean and relube and install. On a daily driver you are lookin at every 6-8 months depending on the offroad runs. If you are undecided on what to buy---get the orbits---there awesome (expensive) but awesome.
    some pics (sorry bout the biggun, i dont have a program to fix it.)
  9. the beast
    Oct 15, 2003
    535
    Providence, RI
    I knew Alcan made them. I was wondering if anyone else did. I'll probably just buy the joints and install them in a different set of springs.
    So I don't think I've seen anyone with a FULLSIZE actually post up that their using them....:doah:
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Do they actually have them on the site? couldn't find the page....
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    hmmm, I must have had some old home page cached or something... got it now, thanks...
  13. 79k20350
    Nov 22, 2004
    7,757
    Ct
    you cant do that, the eye is 2.5" in diameter. it will only work with their springs
  14. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    I don't think you can just buy the joints and install them in your springs, they use a much bigger spring eye than normal. Plus they have to be secured in place in the springs. I think that usually is a tack weld.
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    I think i hear an echo:crazy::D
  16. the beast
    Oct 15, 2003
    535
    Providence, RI
    :doah: I wanted to put them in some BDS springs.....
  17. 79k20350
    Nov 22, 2004
    7,757
    Ct
    The alcans are worth the money... they are much better than BDS and not that much more considering they custom make the spring for you.
  18. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    be easier/cheaper to use them in the hangers rather than the spring eyes. Then you could use whatever brand you prefered/was cheaper etc. I dunno... I've been pondering these for a while and after reading about them lots of pirate etc, I'm considering pivoting perches for the rear instead. An orbit eye on one end probably wouldn't be as effective at reducing twist on the leaf as a pivoting perch would be.
    j
  19. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
  20. the beast
    Oct 15, 2003
    535
    Providence, RI
    But do Alcans come with a "lifetime warranty?" :deal:
    So did Kurt custom make that shackle flip or do the orbit eyes fit the way he makes them? How about at the Front hangers? Sounds like I could get the best of both worlds.....
