ord 0 rate+60+x-over =problems?
Discussion in 'The Garage' started by surpip, Aug 6, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i want to move my axel forward 1 or 1 1.2 in but i have heard this causes problems? anny input?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I will be moving mine ahead 3 inches and I plan on using crossover steering with a d60
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    No problems here, I moved mine 1.5" forward with the ORD 0 rates and used a Rockstomper 1.5" tie rod and drag link. I have over 1/2" of clearance between the tie rod and spring.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    awsome good news thanks
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have a similar setup without any problems (zero rates, Sky crossover).
  6. PJTPW
    PJTPW 1/2 ton status
    Jan 14, 2003
    226
    Moab, Utah
    To really know if it will cause problems you'd need to know if the previous posters rotated their pinion up or not. Also if they turned the knuckles if the pinion was roated up. Spring heights (thicker packs) can pose problems as well.
    If you plan on going high steer, moving the axle forward can also cause clearance problems between the tie rod and drag link with both of them above the springs. Especially with thicker diameter tubes.
    Ryan
  7. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    no probs here...
    j
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Like the other guys said, don't sweat it /forums/images/graemlins/thumb.gif
    (No pinion adjustments on mine)
