ORD 1" Body Lift
Discussion in 'The Garage' started by Bross82, Jan 14, 2007.
  1. Bross82
    Bross82 1/2 ton status
    Feb 11, 2002
    215
    Spencer, MA
    Hi, I was looking at getting the ORD 1" Body Lift for an 85 K5 that already has a 4" suspension lift. Will the stock steering shaft still work out ok? Is there anything else to consider besides this?
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    No problems with the steering. Put the pucks in and rag on it!
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if its an auto you will need to adjust the shifter linkage. maybe also the t-case shifter linkage. might need to trim the fan shroud.
  4. koldsimer
    Jan 10, 2005
    1,480
    texas
    Good point about the fan shroud. After I put in the ord kit, I noticed my fan was really close. A little more poking around found that my motor mounts were worn. Replaced those and it gave me enough clearance to run it.
