ORD add-a-leaf review is finished
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Oct 30, 2000.
  1. CK5
    May 19, 1999
    21,627
    704
    CO
  2. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Steve,
    Looks easy enough. Is there any need for some sort of spacer to eliminate noise?
    Doesn't look like much play done there, but haven't taken apart a spring before.
  3. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Steve, It doesn't like you have a wedge shim in your rear springs. Is this correct, and if so, do you not need then with the ORD shackle flip?
    By the way, thank you for the site and the research you do for all of us(like you don't enjoy it!!!).
  4. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Steve,
    I read the review and it looks good. I noticed you're still running the spacers on the rear. How are they holding up? What size tires are you bolting up to those bad boys? Thanks. [​IMG]
    It's not what you buy, it's what you build!
  5. CK5
    May 19, 1999
    21,627
    704
    CO
    The spacers are great, I run 36x12.5 16" TSL radials on 16x10 Alum rims. I don't have any shims, but my t-case is lowered.
    5,000 Pounds of American Rolling Steel
  6. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    QUESTIONS: Whats the difference between the add leaf and 1" blocks? Do you need to lower the t-case when using a 4" lift (are shims on the springs the alternative)? If you lower the t-case does it affect the clearence and attachment of headers? Thanks.
  7. CK5
    May 19, 1999
    21,627
    704
    CO
    Blocks are placed in between the spring pack and the spring pad while add-a-leafs have the center pin run through them to become part of the spring pack. You may or may nor have to lower the tcase with a 4" lift, things like tcase and tranny models really play with angles, the best thing to do is use an angle finder and make sure your tcase and yoke are not off more that 2 degrees.Shims are one way of moving the pinion up to get within that 2 degrees, lowering the tcase is another or a combination could be used. You should be fine with header clearance when moving the tcase down, however when running full length headers you may come close to the front shackle bolts. A CV style driveshaft can really help with angles as well.
  8. rubiconchevy
    rubiconchevy Registered Member
    Oct 29, 2000
    49
    Tracy,CA
    ok. I need it. How much?
  9. CK5
    May 19, 1999
    21,627
    704
    CO
    I think they are around 30 bucks and include new center pins.
