ORD add a leafs w/ shims??
Discussion in 'The Garage' started by wakedog, Sep 27, 2002.
  1. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    I have shims in the frontend, now when i install the add a leafs would these go on top of the add a leafs or under?? Thanks
  2. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Just to clarify....the ORD product is the Zero-Rate. That's what we're talking about, right?
    If so, the zero-rate will bolt to the existing spingpack using the new spring pin supplied with the kit....My guess is that your shims are not designed to be bolted to the pack, so they would simply go underneath the "new" springpack/zero-rate assembly.
    If the shims ARE designed to bolt to the pack, I'd still put them on the very bottom. Otherwise you are going to "tweak" the spring bolt by shimming it in the middle.
    ....Hard to explain, but hoepfully you got the idea. /forums/images/icons/tongue.gif
  3. wakedog
    Mar 7, 2001
    233
    Minnesota
    Thanks Greg. Ya i was talking about the zero rates sorry for the confusion. As of now the the shims are bolted to the leafs spings with the center pin. I think i am going to bolt the shim to the pack underneath the ORD zero rate.
