ORD Bolt-in Steering Box Brace Kit and Weld-in Frame Repair kit.
Discussion in 'The Garage' started by Blue90, Mar 22, 2007.
  1. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    I've recently discovered some small cracks in my frame rail around the
    steering box. I guess at this point I should purchase the weld on repair kit that ORD offers to fix that. What I'm wondering is if i purchase the repair kit will i still be able to use my bolt on brace from them? :confused:
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, you can use both and I would use both if you are seeing cracks now. Fix the cracks, weld on the repair kit and use the bolt on kit also.
  3. Blue90
    Aug 27, 2004
    583
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I have heard about drilling a small hole at the ends of the crack before but certainly using a grinder to create a "V" and welding is the way to go. So if your welds are good drilling the hole won't hurt;)
    All said by a guy (me) who doesn't weld but has read about it a lot:rolleyes::bow:
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, drilling a hole at the end of the crack creates a stopping point, the crack can't travel any further. V-groove the cracks, fill weld them up then weld in the repair plate
  6. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    I just installed both braces on my rig.... Its a pretty straight forward install... ORD has the weld in brace on back order so i got mine from wheel parts .
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What they all said. My 1st k5 I had just the weld on kit, it worked but the frame still flex. On my current k5 I have both, and the steering is tighter then ever.
